Question about Maytag M7Q08F2ACOM Air Conditioner
Has power but won't kick on.
Won't turn on
  • lildirty721 Jun 20, 2009
    There's enough power going to it. The lights all turn on in front. It is the correct model # too. It will not kick over to blow out cold air. It's kinda along the lines of when your car don't turn over and start.
  • John Tripp
    John Tripp May 11, 2010
    Look behind the front panel on base of frame for the correct model number. Thank You
    President:
  • 3,085 Answers
These ac units are notorious for having bad fans
Posted on Jul 20, 2009
  • Maytag Master
  • 4,655 Answers
If your compressor is having trouble starting I would consider replacing the start Capacitor. Some units have dual capacitor 1 for fan and the other for compressor. If you know how to read an ohm meter I can tell you how to test the capacitor and the compressor windings. At this point in time the question is open until you unplug and check each place Just Ask Joe is correct also. I always ask for the model number because that gives me a picture on my end of directing you. Go to my site and read the testing compressor for burn out and at the bottom of page is a movie about how to work and test capacitor's.Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 20, 2009
  • 10,865 Answers
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
  • Wiring (Inspect for any broken or burnt wiring)
  • Thermostat
  • Compressor
  • Overload and/or relay
  • Selector switch
  • Control board
Cooling fan won't come on when I turn on the AC
Your bigger problem is the compressor not kicking in. The cooling fan is not coming on because there is not enough high side pressure to turn the fan on. I would start by checking power to the compressor, fuses and relays would be inspect. Check to make sure there is the proper charge of refridegerant in the system.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 29, 2012 | 1988 Chevrolet Cavalier Z24
Dynamark riding lawn mower won't start, new battery but will not turn over?
use jumper cable to test the starter if ok jump the small wire at the solenoid to power and see if it kicks it over if yes check the safety switches
May 13, 2012 | Garden
Bogging
Make sure the fuel pump is kicking on it won't hurt to check the relay but I have never seen one bad yet it could be the plug on the plug on the end of the wires that plugs on the pump this run hot and it burns the ends alot several fuel pumps are replaced because of this make sure you have power at the pump if you can't hear it run it will only stay powered for a few seconds and then kick off. so you might need someone to turn it on while someone checks the power.
Dec 29, 2011 | 2000 Pontiac Grand Am GT
A/C Compressor won't turn on Can jump compressor from battery and compressor comes on & cools. Hi pressure switch checks out ok and 12 volts going to hi pressure switch no voltage to compressor
the high pressure switch kicks the compressor off when the pressure rises, the low pressure switch kicks it on, check that switch, unplug the wire and use a continuity meter to see if the switch functions, also check for power getting to the plug itself
Sep 25, 2011 | 2002 Chevrolet Blazer
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 04, 2011 | Maytag Dryers
I'm tryin to find out if my a/c compressor is out. So I know that the dealer said that I need it charged and I didn't get it done. So lately it has been makin a loud noise and rattlin on the...
You may be having AC problems but that is not what happened when the Steering locked unless the AC is on the same belt as the Power steering unit. That whining you are hearing when you turn is actually the power steering unit being low on fluid or the power steering pump going out. Based on what you have described my guess is that the unit has gone out and needs to be replaced. As far as the AC compressor is concerned, if the unit is low on Freon it will not engage once it gets too low unless the clutch goes out. When you look at the center of the AC compressor when the engine is running and the AC is off you should see the pulley free spinning and the very center of the pulley won't be spinning, that is the clutch Dis-engaged. When you turn the AC on the Clutch should engage and allow the compressor to work. You will hear it kick in and kick out repeatedly if it is low on Freon. If it is too low it will never kick in because the low pressure switch won't allow it.
Jun 16, 2011 | 1995 Oldsmobile Aurora
My 83 yamaha maxim won't kick over. It has power and its getting gas. I'm stumped. Need help!
Hi and welcome to the site,
Initially, by "won\'t kick over", do you mean the starter will not turn? If yes, check the starter relay. To locate the starter relay, follow the cable from the battery's + terminal.
If on the other hand, the starter will spin but engine will not catch, then check for presence of spark on the plugs.
Good luck and thank you for asking.
Aug 28, 2010 | 1983 Yamaha XJ 650
Air condition compressor won;t kick in
Most likely a loss of refrigerant ( freon ) in the system. The A/C compressor uses a low pressure switch as a SAFETY to insure it wont turn on without freon in the system. Hope this helps.
May 18, 2009 | 1999 Chevrolet Lumina
Maytag M7Q08F2ACOM Air Conditioner Logo
210 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
