Question about Arts & Letters Arts and Letters Express
Arts & Letters exress download issues with windows 8
I have Arts & Letters 7 and have used it for years. I now have a new 8.1 computer and I cannot download it to the new computer. Is there any solution? kimkamensky@aol.com
First hing I would check is to make sure it is compatible with 8.1. Was version 7 installed under 8.1 or an earlier flavour?
Sep 30, 2014 | Computers & Internet
Having trouble with arts & letters express 8.5 downloaded to windows 8
I figured it out. It my own fault, my computer had a bad memory stick. Once I replaced it, my Arts & Letters Express 8.5 worked perfectly. This is the best program for creating graphics.
Apr 21, 2014 | Arts & Letters Computers & Internet
Download and installation of Express 8
The software for 32-bit systems, which runs on 64 bit windows 7, is located at http://www.arts-letters.com/. A copy with license key is available for purchase.
Feb 28, 2014 | Arts & Letters Arts and Letters Express
Rearrange letters
From Wikipedia:
Littoral art is a term used by Canadian artist and writer Bruce Barber to describe art occurring outside of the institutions of the artworld
Oct 20, 2013 | Toys
Prints on partial page of an 81/2 x 11 photo paper. Prints OK letters fm word.
Instead of using the Letter or factory 8 1/2 x 11 page set up, create a custom page size for 8 1/2x11 and use that in your app for the page set up. Double check your page orientation and the size of the photo you are printing. It sounds like it may be trying to tile the photo because it's too large for the page size.
Sep 14, 2017 | HP Photosmart C6280 Printer
I have windows 8 and can't download my sims deluxe edition
Buy the real one. I know you want it free but if it won't work just buy it.
Jan 27, 2013 | EA - Electronic Arts The Sims Deluxe...
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
I am trying to install the sims 3 nd it is telling me that my code is wrong. What do i do
Double check your code to make sure your not entering a character wrong. Some of the letters look very alike, and some numbers look like letters, and vice versa. B and 8, for example. Try changing out characters that look very similar to each other, and see if that helps.
Oct 04, 2010 | EA - Electronic Arts Sims: Complete...
Computers & Internet Logo
Top Arts & Letters Computers & Internet Experts
David Payne
David Payne
Are you an Arts & Letters Computer and Internet Expert? Answer questions, earn points and help others
