Question about Garmin iQue 3600 GPS Receiver
Garmin 3600 shuts off by itself and i have to reset it
When i put my gps on my auto dock,it shows it has power.i turn the gps
on and it locks onto the satallites,but then after a few minutes it just
shuts off. the screan goes black and i have to reset it.
  • catsailor825 Oct 21, 2009
    I have the same problem. Happens with aux power as well as internal battery. Device continues to shut down and turn back on only to shut down and continually repeat sycle. Only happens with GPS when antenna is activated, other PDA functions are OK.
    Brigadier General:
  • 4,090 Answers
Battery is possibly not in good condition
Posted on Jun 20, 2009
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
Garmin wont turn on
IQ-M4 may be different but f it is like the IQ-3600 then press POWER button while pressing RESET then release POWER button.
Aug 08, 2008 | Garmin iQue 3600 GPS Receiver
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Sep 18, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
Did you try to do ANOTHER hard reset?
Aug 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
266 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
