Question about Vizio VL420M 42 in. HDTV
Can't turn on CC - Vizio VL420M 42 in. HDTV
Can I turn on cc only when my Dish Vip622 is on mute?
That's the way CC usually works. You can verify this by turning mute on and off.
Dec 16, 2015 | DISH Network Televison & Video
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Dec 31, 2014 | Toshiba 51H84 51" Rear Projection...
How do you turn off Analofg Closed Caption?
if your remote has a CC button press it
Nov 02, 2017 | Insignia Televison & Video
Trying to start mini quadard 49 cc model atv-2
Try turning the carb set screw all the way in and back out 1 1/4 turns. If you need more... do it in 1/4 turn increments.
Dec 24, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
LG 42LS3400 CC option is greyed out and I cannot turn off close captions! Help!
try to go to menu then enter close caption CC option then turn it OFF
Jun 05, 2012 | Televison & Video
There is a black (blackend out) square in the middle of the tv screen. the channel shows around the black square. when i turn the tv off and back on it is gone for a while.
Check the closed captioning. there are several modes for the CC features and some of them will do exactly what you describe. check the menu for CC and turn it off. there may be a CC button on your remote as well. it will work as a toggle to turn the CC on and off and in some cases will trun on and then go through the various CC modes then it will turn off. the display will show CC1 then CC2 etc until you get to CC off.
Mar 13, 2011 | Insignia NS-14FCT TV
How do i remove the CC on a Hitachi P50H401?
There should be a key on the remote labeled "cc." If you press this until the message "cc off" or a similar message appears, it should turn off the closed captioning. If you don't have the remote, or if it doesn't have the "cc" key, there should be an option under the tv menu to turn off the cc. Good luck! Der Strom
Apr 08, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Sanyo model ds25390 cc won't turn off
You may have to find an original remote,,,,the options are in the menu...search and ye shall find.
Oct 10, 2009 | Sanyo DS25390 TV
I have a philips magnavox tv with the original remote. closed caption constantly (writing script)comes on tv screen, even though the remote has a cc button,i press it until cc off comes on, the cc goes off...
You're not doing anything wrong. Your TV is somehow turning the cc on "all by itself". Some bit is getting flipped inside the TV, turning the cc on.
either that or there is some sort of rf or ir interference near the TV that is mimicking the CC button on the remote.
Have you pressed the cc button on the remote, verified the cc is "off" on the TV and then removed the batteries from the remote for a while to make sure there isn't something hinky with the remote???
Feb 27, 2009 | Televison & Video
Vizio VL420M 42 in. HDTV Logo
18 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
