Screen goes black after a few minutes. Everything else works fine but the screen goes blank Model No. L32HD32D
  • 854 Answers
Check secondary power supply. check capacitors and apply fresh solder.
Posted on Jun 19, 2009
Rca tv/dvd combo L32HD32D powers on and for 2 seconds shows, Please Wait, on the screen then goes black. What do i do?
After the screen goes black, do you still have sound or you have none but a blank screen? If you have no picture and sound does the power LED in front of the tv indicate that the set is on, or does it go into standby? Please provide this info so that I can help you with your problem.
Sai.
Aug 15, 2011 | RCA L32HD32D 32 in. LCD HDTV
I am trying to diagnose a problem with my son's laptop screen going blank. I shall try to describe the symptoms. 1. When plugged into an external monitor, everything works fine. 2.The laptop screen...
Have you check the cable that goes from the screen at the motherboard? Usually this cable is not visible; it is hidden it one of the joints between screen and main body of the notebook.This cable is the most common problem in the cases that the notebook keeps on working although the screen is black. You can check it by opening slowly - slowly the screen all the way up and closing again slowly. If there is a cut at the cable your screen will get black at a specific slope.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 31, 2010 | Dell Inspiron 6400 Notebook
TV goes to blank screen after turning it on (about 3 to 4 minutes) but I can still hear it fine. I turn it off and wait a few minutes(5) then turn it back on everything is normal then it goes back to blank...
This tv the LCD inverter board is dead,that why is not sustanning backlight for the LCD screen light to have the picture.Call Polaroid for warrenty repair,this tv under a year old.
Jun 07, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 13, 2010 | RCA L32HD32D 32 in. LCD HDTV
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
