Question about Canon Cameras
Canon ixus 230 hs lens not closing - Canon Cameras
  • 48 Answers
SOURCE: lens error
Hello
No simple fix for this one, sounds like lens block is faulty and probably need to be replaced.
Suggest you contact a local service center for pricing.
Posted on Oct 03, 2008
samrat_babui
  • 296 Answers
SOURCE: Canon Ixus 860 lens
hi
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are within warranty period and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
all the best.
thankyou.
Posted on May 05, 2009
t00nz
  • 4738 Answers
SOURCE: how to fix canon ixus 7o lens error restart camera?
Do you mean its taking black pictures? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 05, 2009
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
regards iversh
a very helpful rating is apreciated for answering ur query.....
Posted on Aug 19, 2009
BillB-SA
  • 2761 Answers
SOURCE: how to restart Canon IXUS 70
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
There is a shadow on lens
  • check the lens for any physical damage (cracks , dust etc. ) wipe the lens using a lens cloth .
Jul 20, 2014 | Canon Powershot Elph 100 Hs / Ixus 115...
Canon ixus 115 hs memory card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 09, 2014 | Canon IXUS 115 HS Digtal Camera
Water Damage Lens Error
Most cameras with retractable lenses are very sensitive to grit (sand, dirt, salt etc.) in the lens mechanics and will shut themselves off if everything is not perfect. It's possible some salty water remained in the works and left a salty residue when it dried out.
Unfortunately, most repair shops will charge you almost what the camera is worth to properly clean it and it is not a job for the do-it-yourselfer.
Apr 27, 2017 | Canon SD4000 IS IXUS 300 HS Digital Camera
How to unlock memory card
May 23, 2013 | Canon IXUS 230 HS 12 MEGAPIXEL 8X OPTICAL...
Error message on ixus 1000hs
I assume the error message says "Lens Error"? Try the procedures in this tip.
Jul 26, 2012 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
Getting a constant lens error message and the lens will only partially retract Thanks
Make sure there's nothing stuck around the edges.
I don't suggest fooling around with it too much as digitals break fairly easily, so take it to your local camera shop and see what they can do for you.
Mar 02, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
Canon Ixus 860 lens
hi
all the best.
thankyou.
May 05, 2009 | Canon IXUS 860 IS Digital Camera
Cameras Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
