Question about Bosch Nexxt 300 Series WFMC2201UC
Popping (electric) sound from back. Caused breaker to pop. Opened unit to get a better look, nothing broken or blackened. Reset breaker. and turned machine "on". No more popping sound. Washer only fills & drains but does not agitate nor spin. Door is locked closed. I am comfortable replaing any broken or defective parts. Thank you for your time. David
  • 1 more comment
  • eatchocolate Jul 05, 2009
    ajs_biz: Thank you for the solution. Where do I find this capacitor as I see nothing as described? Is it on/at/near the motoer or in a housing of black & white plastic located at the back bottom-right of the washer? Thank you.
  • eatchocolate Jul 28, 2009
    AGAIN I will ask a follow-up question: I have paid for the service, written to ask for help and yet I have received no reply!!- WHERE!! do I look for the capaictor??? I have two options: near the motor OR in a seperate housing unit. Please, somebody, respond to the service for which I have paid and answer the question or return my money.
  • eatchocolate Jul 29, 2009
    THANK YOU!!! so much for answering my question. AS per instructions I removed the motor to search for capacitor- nothing there that remotely looks as a cap.
    Supressor looks O.K. Checked sup. output amps: what should that read if working properly? If sup. not damaged what is next move? Also, can machine tell me using codes what is broken? How is that process done. Thank you.
  • 109 Answers
Have a look at the capacitor, this is part of the starting circuit for the electric motor.
It is a cylindrical shape and usually splits or bulges.
Post again if you need further assistance.
Posted on Jun 19, 2009
  • Adrian Jul 29, 2009
    Sorry I Haven't got back to you, it seems fixya.com charged you and the experts don't get anything.
    The capacitor should be mounted on the wash motor, this could be the problem or it could be a suppressor which is normally where the main power cable plugs into at the back of the machine.
    If you find the suppressor, just look at it and you will see if it the problem as they have black carbon burnt like marks or they just blow out.
    Thanks.
Why doesn't it work?
I would check and see if the power supply and electrical connections are solid
Aug 06, 2015 | Dishwashers
I turn on compressor starts working but it turns back of agian
If the motor circuit breaker is popping off as you state, it's either bad or the power supply is inadequate. It's not all that rare for the circuit breakers on electric motors to go bad. When they go bad they either won't reset or pop off at lower and lower amperages. Another cause could be that the motor is essentially trying to pull too much electricity through a line that can't handle it. This would be caused by using too many, to long or too small guage extension cords. Always plug the compressor into an outlet and run longer air lines than use extension cords. On some occasions if you are too far from the breaker box and the lines to the outlet are low guage you can get the same affect.
Aug 19, 2012 | Ridgid FactoryReconditioned 12 HP 5Gallon...
My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I turned on my oven on my Frigidaire Range and heard a popping sound. This blew the breaker. I turned the breaker back on and the stove top works but the oven, broiler and bake do not work at all. The...
To be certain the elements are o/k you need to test them with a meter. I suspect one of them has failed.
You normally cannot always tell if they are o/k simply by looking at them.
Hope this helps.
Jan 11, 2010 | Frigidaire FEB27S5A Electric Single Oven
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
The jenair made a popping sound, wasn't even turned on. Then found it didn't work at all. Flipped the breaker, and it would immediately flip back, the Jenair would also make the same popping sound.... Do...
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number).
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity (the down draft cavity is where the grease guard mesh is)
Oct 06, 2009 | Jenn-Air JED8430 Electric Cooktop
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
May 28, 2009 | Kitchen Ranges
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bosch Nexxt 300 Series WFMC2201UC Logo
146 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
