Element tv troubleshooting
TV WANT SCAN CHANNEL
SOURCE: Element TV remote control
Our Vizio TV came with the same problem and my husband just figured out how to fix this... Go to menu then TV at the top and go down to skip channel. Uncheck all boxes and this should solve the problem. Hope it helps.
Posted on Apr 18, 2009
SOURCE: Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
Posted on Jun 03, 2009
SOURCE: I need to do a
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
Posted on Oct 18, 2010
  • 126 Answers
SOURCE: i have a flat screen element 32 inch tv and my
if your using cable then the tv is probably on an input instead of TV or antenna
Posted on Dec 04, 2010
SD Tech
  • 14553 Answers
SOURCE: no pic please run channel auto scan
It means it is not detecting signal etc.
If you had a power outage unplug the set for a short period of time and plug it back----if using a box for signal do the same.
This may allow set or box to reboot and function again.
Also you can try to hook a DVD etc to a rear audio/video input to see if that works.
Posted on Apr 01, 2012
I have a 50 in element tv.. it is only a year old. I used it at my house first, then I moved to college, when I plugged it in in my apartment I couldn't get the cable to work.. This tv is in my bedroom,...
See if another set works there to make sure that the cable is providing signal. If it is then the tuner on set is fubar - you can always get an external tuner and plug it into your set's audio/video input or HDMI or whatever you got.
Aug 23, 2017 | Element Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
How to do a channel setup on a 32" element TV model no. ELEFW328 HDMI .
somehwere in the main menu there should be auto scan. look for that then do it depends on what type of input you set in also Cable,sat, or antenna
Feb 10, 2015 | Element Televison & Video
My element tv will not show above channel 27
did you set it to cable an then do a channel scan
Aug 17, 2014 | Element Electronics Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Tv setup - cannot get past auto channel
Connect the TV to the Comcast box using an HDMI cable, then set input on the TV to HDMI - that's all. You then select channels on the Comcast box , not the TV (although the TV remote can be programmed to change channels on the cable box)>
Jan 27, 2014 | Element Televison & Video
Insignia tv troubleshooting
Channel scan is nothing, but an auto-tuning. Refer its user manual for details.
Dec 17, 2013 | Televison & Video
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
