Question about Case Logic Computers & Internet
How to sync up Bluetooth keyboard with iPad
How to activate the case logic Bluetooth keyboard with my iPad
5 Suggested Answers
SOURCE: Need help with Case Logic bluetooth ear piece model BTH-10
The generic PIN for that bluetooth is : 1234
Good luck
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: case logic keyboard, no soft ware with key board,
u most likely got US layout printed on your keyboard and UK keyboard set in your operating system (OS). U have to change the language/keyboard layout to EN (US) if u want the keyboard to work as it shows. Might be that u have to install this language from your widows CD as if u not choose more languages when installing OS, it will only install the one that is predefined. U can find this setting in control panel >>>regional and language options>> languages>> input language>> click on details and it will show u all options available. On top is default input language, under that is window with all languages u can chose, if there is EN (US), cool, if not u have to add a language. when EN (US) will show in that window jobs almost done. If u will find any other services that u don't need (CZ, PL,FR etc.) remove them! Than u have to chose if u want to change the default layout. If u want to have everything as keyb. shows since OS starts u have to change default to EN (US). And that's all.. Option 2 is that u will keep EN (UK) as def and US as "spare input" and only by pressing hotkey alt+shift easily change the temporally layout whenever u want. just when u decide for option 2 ensure that OS will show language bar on taskbar.U can set this by clicking on right mouse button in taskbar area chose toolbars and thick language bar. U will see always EN as the mark for input they are the same for us and uk, but by clicking on it it will show u details quick and easy.. Or there is also a option 3.. u can just find @ under ". They are just swap over and u don't have to change anything. but I'm sure if u take option 3 that u will find more things that u will not be to able to find on US keyb. with UK input on OS.
Posted on Jul 18, 2010
cdq8f
SOURCE: Just got the leather Vivitar
MY Vivitar keyboard is not working with my ipad 2. It used to work fine but not any more. Pls. help.
Posted on Aug 07, 2012
  • 928 Answers
SOURCE: I forgot how to connect my DG Bluetooth Keyboard Case to my iPad. Can you help please?
It should be just like pairing an audio Bluetooth device. Turn the iPad's Bluetooth on and the keyboard as well, the iPad will look for an available device, it should pop up in the iPad, tap it to pair, if its ask for a pairing number, it should be noted in the box that came with the keyboard or in the instructions, that should be it.
Posted on Mar 10, 2015
Mar 10, 2015 | Computers & Internet
How do I get my Coverbot to connect to my IPad air with bluetooth
Check your batteries in the Coverbot to make sure they are fresh. Next, make sure the Bluetooth is turned on within the iPad. Make sure the Coverbot is turned on. Click on the "Search for devices " in the Blutooth menu on the iPad. When you see your Coverbot come up, click on "Connect".
Attached is a Coverbot Youtube video, it may be of help to you. Also, attached are the directions from Coverbot. Good luck!
Nov 25, 2014 | CoverBot iPad mini Keyboard Case and Stand...
Keyboard won't stay on?
Watch this link I posted here. Maybe this could help you out. Maybe the bluetooth is not enabled in either your ipad or your keyboard.
Logitech Keyboard Case for iPad 2 Setting up and Bluetooth Pairing
Oct 17, 2014 | Apple Leather Case Cover With Keyboard For...
Using the keyboard for iPad not typing on the screen
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Sep 15, 2014 | Apple iPad Tablets & eReaders
Kensington keyboard manual
Your model number isn't listed, but all published Kensington keyboard manuals are available at
http://www.kensington.com/manuals
My keyboard (model K39336) connected easily, so here's what I had to do. Ensure the Ipad Bluetooth is on in settings. Turn on the keyboard, and when you see a single blue light, press the connect button. The iPad will give you a four digit code to type in on the keyboard. When you type in this code, the iPad and keyboard become 'paired' and keyboard input is available whenever the keyboard is turned on.
Aug 18, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Up wand down buttons won't work on coverbot iPad Mini keyboard case
if its nt working for ipad mini..thn software may hav been corrupted.
if the up wand down buttons totally nt working with any program or device then it may b a hardware problm!!! bttr tak it to the service center of the product.!!!
Jan 04, 2014 | CoverBot iPad mini Keyboard Case and Stand...
Www logitech com ithink
Reset the Ipad
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPad will erase everything on it, so make sure everything on the iPad is stored elsewhere prior to restoring. To restore, connect your iPad to a computer with the latest version of iTunes installed. When your iPad appears under the devices menu, click the restore option under the summary tab. If you haven't backed up your data already, choose the back up option from the pop up window. Click the restore button to restore your Touch to factory spec.
Bad logic board
If attempting to restore the iPad and diagnosing does not fix the problem, the issue is probably the logic board.
Dec 05, 2013 | Exercise & Fitness
Need pairing instructions for the case logic ikbt 50 keyboard for an ipad
You probably have the same problem I had. First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
Aug 09, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
Keyboard sync button flashes but will not link with ipad
my keyboard shows that it is connected to my iPad but I can't use my keypad it doesn't show up on the monitor
Jan 20, 2013 | Kensington KeyFolio Bluetooth Keyboard and...
Computers & Internet Logo
11 people viewed this question
Top Case Logic Computers & Internet Experts
Lawrence Oravetz
rdjagger
Are you a Case Logic Computer and Internet Expert? Answer questions, earn points and help others
