Question about Datacard SP35 Printer
Hoper motor to feed the cards - Datacard SP35 Printer
Error code 000025
Plz chek the hoper unit delivery & round motor. the moter has not running
Jul 24, 2014 | Canon ImageRunner Color 3480 | IRC3480 |
Minolta cspro ep 6000
what is the code 0070 ??? what about the motor?????
Apr 18, 2014 | Konica Minolta Office Equipment & Supplies
Laminator wont feed
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
I have a fellowes laminitor and it will not feed
Icemaker clicking loudly model #MFI1226VEM7
It may be the ice full arm is stuck remove some of the cubes from the hoper.
Nov 16, 2013 | Maytag MFF2558VE Bottom Freezer French...
GTA 4 SERIAL NUMBER LOST HELP ME
this is a serial number for GTA 4 :UJEEK-ME33J-JDES3-GEW6X-F3NUV
and this is a seril number for GTA 4 All :H6XMM-CMBQB-64HF3-CHJC9-PVTPQ GFWL
hoper its help and please rate this post
May 14, 2011 | Computers & Internet
How to change the toner to my canon np 6045
There is a panel you open on the Right side of the keypanel.Insert the bottle upsidedown and hook in place slide the plastis handle of the hoper unit to the right and the toner will fall from the bottle inside the hopper unit.Close the hoper unit slide before removing the toner.
Dec 09, 2009 | Canon NP 6050 Copier
Minolta bizhub 420 code c2403
this error code means there is a problem with the toner bottle drive most likely the toner rotation sensor will need to be replaced
Nov 21, 2009 | Konica Minolta Office Equipment & Supplies
Printer problem T6050 ( Tally )
This problem is occure due to Logic Card Problem or Paper feed motor Problem. Bhavin - India
Apr 06, 2007 | Tally Line Matrix T6050 Printer
Datacard SP35 Printer Logo
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
james laughton
james laughton
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
