Question about Karcher 2500 PSI Pressure Washer
My karcher 5.80 has no pressure just a spray - Karcher 2500 PSI Pressure Washer
3 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: on my karcher pressure washer, how do i get the
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Posted on Apr 13, 2009
SOURCE: where can I order this part spray wand extension for the Karcher
i order a new part
thank you for your help.
Posted on Jun 18, 2009
Where can I get a Karcher 410 spray nozzle (bit on end of wand) Karcher don't seem to keep such an old part.
Hi Stephen:
Don't know where you are, but in my location here in Canada, the local LORDCO parts store has a large selection of pressure washer accessories.
I'd suggest that you try to find a similar equipment supply retailer.
Cheers
Nov 06, 2015 | Karcher Garden
My Karcher 720mx moter is working fine but i have no water pressure coming from pump
hi put some silicon spray in inlet and outlet then reconnect hoses what is going on is when you store it the seals start to dry out.........
Jan 13, 2011 | Karcher K3.68MR Electric Pressure Washer
Karcher power spray frost damage
I've found the most useful repair people for power washers are lawn mower repair techs. Give them a ring and see if they do house calls, they'll be your best bet.
Mar 08, 2010 | Karcher Garden
Karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Jul 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
32 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
