Question about Euro-Pro TO160L 1380 Watts Toaster Oven with Convection Cooking
Not heating, but light works? How do I fix this problem?
    Scholar:
  • 53 Answers
Your oven is obviously getting power if the light is on. If your heating elements are not getting hot you may have had a switch go bad, a wire come off it's terminal, or possibly a fuse that blew if your unit has one. There is really no way to know exactly where the problem is without taking the unit apart and visually inspecting it. If all the connections and switches look good, some electrical diagnosing is needed to see where the problem is. If you find any wires or switches that have any melted or burned plastic, you will need to repair the connection or replace the switch. If there is no obvious problem, you should have it looked at by a technician who can properly diagnose the unit.
Posted on Aug 04, 2014
How to fix Euro-Pro toaster oven?
Don't waste your time, the parts will cost more than buying a new one.
May 12, 2016 | Euro-Pro Kitchen TO36 Stainless Steel...
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Hamilton beach 31197
Look for the thermal cutoff. Either it looks like a resister or it looks like circular thing. Test it for continuity
Oct 18, 2013 | Toaster Ovens
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
TR0651WC Black & Decker Toater Oven. Stopped working all together
Trace the electrical circuit with a multi-meter, while unplugged.
May 08, 2017 | Euro-Pro EP278 Bravetti Platinum 1500...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
KitchenAid toaster oven Mod# KC010058
The overload switch is located above the theromostat.To check it put a jumper across the switch and plug the unit in. If the switch is bad you will now see the red light on and the oven will work. Take the switch off and gently pry the 4 posts back. Remove the pin, gently put it in a vise and put a drop of solder on top of the metal cap. Put the switch back togther, install it and you should be back in operation.
Oct 21, 2007 | KitchenAid KCO1005OB 1400 Watts Toaster...
Euro-Pro TO160L 1380 Watts Toaster Oven with Convection Cooking Logo
155 people viewed this question
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
