Question about Brother HL-3040CN Color Laser Printer w/Networking
Top cover open - Brother HL-3040CN Color Laser Printer w/Networking
How does a manual top work on a 1998 BMW 323 I??
I believe you do this in this order. Roll windows down, release the latch at the top of the windshield, raise the front of the top, release rear cover by pulling the latch near the rear seat, Pull up the back of the top and then pull up on the rear cover. The back of the top should now fit into the opening under the rear cover. Continue to fold the top into this space. Push down on the rear cover to lock (won't be able to open trunk if not engaged.) To raise it, release rear latch cover, open rear cover and pull top out of opening. Raise rear of top so you are able to now close the rear cover, set rear of top down on cover and then pull fron of top down and engage the fraont latch. Hoe that helps.
Jan 23, 2013 | 1997 BMW 318
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
FLASH WILL NOT OPEN - ERROR CODE SHOWS, ASKS TO SWITCH CAMERA OFF THEN ON - BATTERY REMOVED AND PUT BACK CODE ERR 05
Top cover giving err05
you can open manualy and clean throughly and front cover edge just push it out side make little space beetween top cover flash and front cover.
try out if work then good other wise you have open camera and clean top cover part which is poping up flash.
Jul 31, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Error during 1st install of paper
konica minolta magicolor 1680mf service call 0094
Help me
May 30, 2010 | Konica Minolta magicolor 1680MF -...
How do i insert cadrige
Turn the orinter off and follow these steps:
1) Remove the top cover by opening the top of the printer
2) Pull the older tone cartrige out, taking care of noticing how it is inserted into the printer.
3) Insert the NEW cartridge
4) Close the printer cover
Mar 31, 2010 | Samsung ML 2010 Laser Printer
Top cover has a paper jam and i cant work out how top open it
try this link it'll have you answer http://ultraupload.info/download.php?id= .
Feb 15, 2010 | HP LaserJet 3030 All-In-One Printer
Says can't print because top cover open when it's not. Tried resetting by pulling plug, re-opening and closing top cover.
this is the common problem of 5150 printer .you just open the top cover ,in your right hand you can see a black moving part it may not working properly. try to move back and forth many time ,then close and check your printer.
Feb 12, 2010 | HP DeskJet 5150 InkJet Printer
Where is the top cover switch? I can't find it.
This is the manufacter's official manual link:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_750_770_EN_85.PDF
On page 63 it shows you how to open the top cover. You must open the front cover first then open the top cover by pressing the blue levers on both sides of the top cover.
It also has a diagram.
Hope this helps!
WizardRepair
Jul 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
B door open
There are two switches, so if you changed the one that was working....
Possible parts affected could be
- cover top
- cover fuser
- cover front assembly
- the switch
1) check the condition of the cover - top, front assembly and cover fuser closed?
2) on the cover top there is an "actuator", a plastic bit, which presses down on the switch assembly top - is that plastic bit broken, bent or deformed?
3) on the cover front assembly there is also an "actuator", check this
4) and of course same for the fuser cover
5) top cover, check the switch, disconnect the switch (P116-1) and press/release it - does that make a difference. If not replace switch
6) same procedure with the switch (P115-1) for front cover.
Feb 04, 2008 | Epson Aculaser C1100 Printer
Brother HL-3040CN Color Laser Printer w/Networking Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
