Question about Samsung Washing Machines
WA456DRHDWR/AA leaking from bottom
2 Suggested Answers
t0ny_pars0ns
  • 4413 Answers
SOURCE: My Samsung washer model WA456DRHDWR/AA doesn't have any power. Need help troubleshooting.
Right place - well done.
Posted on Sep 11, 2017
Hey Cindy,
First, makes sure all the breakers have been reset and do not trip when you try to use the washer.. if the breaker trips each time you try to use the washer, then you need to cal a qualified repairman..If the breaker is good and stays on, make sure its plugged in correctly..if its plugged in and you have power at the plug..( are you mechanically inclined?).. if not call the Qualified repairman)..there are several things that will cause it not to work,,
Samsung WA456DRHDWR AA User Manual Check These Solutions If Your Washer...
http://www.appliancepartspros.com/repair-help/samsung-washer-wa456drhdwr-aa-0001-repair
check this out..
Samsung Recalls Top Load Washing Machines Due to Risk of Impact Injuries
Sep 11, 2017 | Samsung Washing Machines
Error code BE1 comes up at spin time & it stops. Common cause?
8e1 Front mems sensor error locates on main board check at main board fir loose harness. Probably a bad sensor or harness get both the sensor itself is under too near front right
Apr 09, 2016 | Samsung WA456DRHDWR: 4.5 cu. ft. King-Size...
My WA456DRHDWR/AA Samsung Washing machine is making a grinding sound, like a belt is messed up. How do I diagnose the problem with no error codes?
open it up and watch while running .washers do not normally have belts would bet the bearings are going the trip
May 02, 2015 | Samsung Washing Machines
How do i reset a Samsung DW80F800UWS with display showing "LE"
Oh, that stands for Leaking - Samsungs have a plastic bottom that catches leaked water which activates a leak detector, which puts up the LEakin message. Most often leaks occur around the drain pump or drain hose. To clear the error, you must remove the standing water under the leak detector; no key sequence will remove that error.
Jan 04, 2015 | Samsung DW80F800UWS/AA 24" Stainless Steel...
My drum has come loose from the bottom where the agitor is how do I get it apart so I can center it again?
I would guess that the bearing is loose or bad.If you lay it on its side you should be able to see whats wrong
Oct 05, 2014 | Samsung High-efficiency Top Load Washer...
I have a Samsung WA456DRHDWR. The drain pump went bad. I wasn't around so I don't know what happen but when I found it the pump had busted out of its' plastic mounting bracket and the 2 wires were dis
2 possible problems:
1. there is a tiny switch in the lower metal base of the machine hit it it might be stuck.
2. you have a problem with an electronic component in the main pcb called triac. this part is acting as a switch you need an electronic repairer to change it
Mar 24, 2014 | Samsung WA456DRHDWR 4.5 cu. ft....
Why does my bleach dispenser cup fill up with water every time I do a load of laundry?
I agree with grady709 about the plugged inlet lines, I had water left in my Samsung front load all the time and made sure the machine level and nothing wrong with venturi. I suddenly had water leaking from somewhere instead and when I took the top off I could feel the line swell up and leak at the fitting. Hose still leaked after replacing. Put a drill bit by hand down the nozzle where the hose clamps on and it was plugged up and also the bleach line was plugged up, also inside where the tray goes there is small holes in the top where the water sprays out can be plugged. Worked for me. Live where the water is hard.
Nov 24, 2012 | Samsung Washing Machines
Do you know how i can dispose of AA leaking alkaline batteries safely?
These can be disposed of in your normal household wast bin. They no longer put mercury in these.
Oct 05, 2012 | Duracell Ultra Alkaline AA Batteries 4/pk...
Washing Machines Logo
14 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
