Macbook air a 1369 backlight
Not working
  • 47 Answers
You will probably have to replace the backlight bulb. You can search ifixit.com for a teardown guide on how to replace the backlight bulb.
Posted on Sep 03, 2014
My friend has the same MacBook Air and her keyboard has backlights, how do I get this on mine
You may think you have the exact same one but your MacBook may not have the backlit feature. Check your manual and see.
Feb 05, 2018 | The Computers & Internet
How replace backlight mac?
The reasons for backlight situation are;
1 bad screen
2. backlight chip being defective on the logic board
3. bad inverter.
It is therefore advised to take your machine to a local mac repair store.
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Aug 29, 2014 | Apple PowerBook G4 Mac Notebook
HyperPen mini does not work
not sure if this link will help you out but have a look... Aiptek Hyperpen Mini ..
or this one... HyperPen mini does not work Google Search
Oct 26, 2017 | Aiptek HyperPen Mini
Forward slash not working on my macbook air
Did you change the system font to one you downloaded from the Internet? Some of those are missing characters. If not,
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Dec 04, 2012 | Apple MacBook Air
MACBOOK BACKLIGHT
Yes I know, how to fix it. Whe you have replaced the LCD, did you also unglued the backscreen sheets? The LED bulbs providing the back light are seated behind these sheets which are glued to the metal. They tend to damage very easeasily. No way to buy them if this is damaged. You will need to buy a damaged, complete back panal. But first check if the wiring is properly done. Here is the guide.http://www.youtube.com/watch?v=eHNtnvzfSzYGood LuckMohan
Aug 02, 2012 | Apple MacBook Air
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
Backlight on my Mac Air is suddenly dimmer than usual. What's going on?
perhaps just a glitch in the software....go to control panel and adjust briteness again....if it don't do the trick, then most likely your bulb has seen better days and needs replacing
Apr 22, 2012 | Apple MacBook Air
Computers & Internet Logo
David Payne
David Payne
