Question about Samsung Wa95v3 7.5kg Washing Machine For 220 Volts-13761
Water is not supplied - Samsung Wa95v3 7.5kg Washing Machine For 220 Volts-13761
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Samsung front load washing machine, WF42H5200AF, less than 4 months old giving code 4e when warm or hot temperature is pushed. Can only wash in eco warm or cold. I have drained and cleaned out to front...
Error code 4E is a water supply error.
Check the following:
  • Foreign material is entering the water supply valve.
  • The water supply valve terminal is not connected.
    (Wire disconnected)
  • The warm water and rinse connectors are wrongly connected to each other.
  • This occurs if the PCB terminal from the drain hose to the
    detergent drawer is not connected. Check whether the transparent hose is folded or torn.
Possible Parts Affected are:
  • Water supply Valve
  • Main PCB
  • Obstruction of the water line.
To Check the water supply:
Check the resistance for the water supply valve. Resistance: 0.9~1.1k? between the terminals of the water supply valve
Jan 28, 2015 | Samsung Washing Machines
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
'Check water supply' light is on.
is the water supply pressure is enough, because there is a pressure sensor at the water supply inlet.
or there is a filter at the water supply inlet which usually can blocked.
Sep 13, 2012 | Dishwashers
Is it a cold water or hot water fill
It's your choice.There's only a single supply hose and with most dishwashers that means cold fill only, but as this is a compact basic worktop model the manual supplied suggests that users connect to a hot water supply.
In real-life situations though, the water drawn from the hot supply often isn't instantly hot so all you do is drain cold or tepid water from the supply pipe and let it get replaced with wasted hot water which then cools in the pipe! If the machine features condenser drying like many dishwashers, then cold water is essential for it to work. A final consideration is that unless your hot water is supplied at mains pressure (such as in a combi-boiler or megaflo system) then the water pressure from a hot water storage tank will not often be high enough and you'll have to use the cold supply.
Jul 13, 2011 | Bush DW5F 22 in. Dishwasher
No water
Try replaceing the water filter, and / or check the water supply for adequit volume and pressure, by disconnecting the water supply line from the back of the refrigerator and run a couple of gallons of water into a bucket just to make sure the line is clear.
If the water supply volume and pressure is good, reconnect the water supply line, install the new water filter and try dispensing water, this should fix it, or check that the water supply silenoid valve for proper operation when dispenser lever is depressed.
GOOD LUCK !
Aug 20, 2010 | Kenmore 57029 Side by Side Refrigerator
Water does not heat up
sounds as if the water supplied to your dishwater is on the cold side supply. Dish washers do not heat water themselves they have the hot water supplied to them from the hot side of the water supply to the house. Very few dishwashers have a water heater hook up built into them.. I would check the water supply to the dishwasher I think there is where your trouble is. Good Luck
Dave
Aug 07, 2009 | Dishwashers
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
No water supply
There are a few checks. Try the #1 first and then proceed to the next one til you get water. Here are a few checks:
  1. Turn off the supply and disconnect the supply line to the dishwasher, turn the water on to flush the line and to check for flow
  2. If you have water to to the supply line, your problem is the water solenoid. Replace the water solenoid.
  3. Turn off the supply, and disconnect the supply line at the shut off, turn the water on to check for flow.
  4. Shut the water off to the house, disassemblehe shut off, clean debris out of shut off. It may need to be flushed. I recommend using a hose to direct the flow into a 5 gallon bucket while someone cycles the water supply.
  5. Replacement of shut off is next.
Please rate this solution.
Aug 03, 2008 | Kenmore 15129 Built-in Dishwasher
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Samsung Wa95v3 7.5kg Washing Machine For 220 Volts-13761 Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
