Question about Garden
Uberhaus canada i need a part for my hose cart reel
Leaking brass fitting on hose reel cart model MI4030-013755. can it be repaired
yes
pull it apart and replace the worn rubber "O" ring
Mar 18, 2017 | Garden
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Uberhaus canada
Usual issue is a worn or misaligned flapper. Could also be worn parts in the fill valve.
Jul 17, 2014 | Home
Rankam
You can get 10" never flat tires with 5/8" hubs that will work. Home Depot has 4 for $59 online.
May 12, 2014 | Ames 225ft. ReelEasy Hose Reel Cart...
Holman retractable hose reel won't retract garden
it is possible the rewinding spring broke .
Jan 07, 2014 | Karcher Hose Reel
" 1500-w wall convector" from uberhaus compared to "1500-w electronic converter" Stelpro
One of the main differences is the stelpro is 110 volts and the uberhaus is 240.
Dec 02, 2013 | Fahrenheat Electric Convector Baseboard...
Disassemble ames model 2398200 water genie
I have removed all screws and opened circular sides. I am unable to pry can apart. The hose is off the reel and one part is loose inside. I believe it is the hose guide. Any ideas? Next step garbage can and I won't be buying products made in China again! Thanks
Nov 12, 2012 | Ames 2398200 True Temper Water Genie Hose...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
