Question about Sony PlayStation 2 Slimline Console
I put on a ps2 disk or movie on my ps2. the cd dosen't seem to spin but the laser flashes and it moves so i tried to clean the laser. it failed. then i tap the top part of the ps2 . when i did that the laser moved but when i stop tapping it it didnt move. i reseted a couple of times but i didn't move. so i had to put tape on the top of the ps2 so that the laser can spin. while i did that i put the disk but it doesnt do a thing. the laser flashes and moves but the disk doesn't spin. What The Hell???? Someone Help!!!!!
    President:
  • 2,653 Answers
Your laser is dead. You've got to replace it.
That's it.
Posted on Jun 19, 2009
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
The disk do`snt spin
No Spin At All
If your spindle hub is NOT SPINNING AT ALL,
NOT EVEN 1/2 OF A TURN, it may be bad or unplugged.
A tell tale sign of it being unplugged is if you hit
eject, the laser moves down the rail, and starts
grinding because the PS2 keeps trying to move it
down the rail even though it hit the end. There's a
small switch on the spindle hub that tells the unit
to stop pushing the laser because it's reached the
end. Spindle hubs usually do not go bad by themselves,
usually either the PS2 too a bad fall and it became
bent [try spinning it by hand], or someone the cable
out and put it in too many times [or incorrectly] and
the silver contacts on the cable were detached.
Reasons for 1/2 spin:
1. A dirty laser. Try cleaning the laser and see if it helps.
If you can see crust or dust covering the laser eye, it may
not be strong enough to read anything at all. If the laser
looks clean, this is probably not the issue.
2. An unplugged laser cable. These things normally do not come
out by themselves, but if you opened the ps2 that was spinning
OK to clean the laser and/or removed the laser to clean it,
plugged it in, now it's spinning 1/2 of a turn, the laser cable
may not be in securely. If it is in securely, make sure it is
plugged into the motherboard end properly.
3. A dead laser. On models 30001, 35001, and some 30001R, this
is the most likely issue. These models are old and the original
lasers were a bit unreliable.
Dec 06, 2009 | Sony PlayStation 2 (PS2) Console
My Slim PS2 discs won't spin. I just replaced the laser...
put some wieght on the ps2 disk cover flap eg a game cover that fixed mine otherwise i would trash it man ;)
Jul 26, 2009 | Sony PlayStation 2 Slimline Console
The disk isn't spinning. When tray closes, it tries to spin for a moment, but then it doesn'tt.
When you first put a CD/DVD into the Playstation 2, the disc spins enough so that the laser can read if it's a CD, DVD movie, DVD ps2 game or CD ps1 or 2 game to spin at the appropriate speed. If there is no disc inside, or the laser thinks there is no disc inside, the disc will only spin that 1/2 of a turn. So what would cause the laser to think there is no disc inside?
A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable. I would suggest using a 400C since it is a better laser [and more available] than the 400B. YES, despite anything you have read, you CAN replace a 400B with a 400C IN ALL CASES.
Jun 05, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 slimline.... disc doesnt spin, laser not flashing or moving... no data on browser
My ps2 has/had the same problem, it wouldn't read DVD movies at all and ps1 games were always hit or miss. The only two solutions i can suggest are cleaning the lens or replacing the little cotton pad that holds the disk in place near the laser. This seemed to fix it for me, it works about 85% of the time now. Hope one of these helps
Apr 16, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slim New Lens, Not Spinning
Hi guys,
Well, there is 2 switch. one at  the back left of the cd tray and one one the reset /power switch. both sitch have to be close in order for the disk to spin.
If you try this dont forget to put a disk on the spindle as you will start the laser. this is for your safety. then, if the disk does not spin, then you can try replacing the laser. or at least verify the ribbon cable that is hook to it. if the ribbon cable is not well inside the plug the laser might move but again the disk won t spin.
it is related to each other, the PS2 seem to verify the laser prior to start the spindle so what ever happend to the laser affect the spindle.
and then, if you buy a new laser lens, don't forget to remove the soldering bridge. it is a small ball that is use to avoid static while shiping the lens.
most of the seller will include a small peace of paper with procedure and also there is web site with picture of this soldering bridge.
I replace some of them, and I have to say that the small plastic lock for the ribbon  cable to the lens has been an issue and the soldering bridge another one.
but I got most of the PS2 back and running by replacing the laser.
I hope this will help you.
Feb 26, 2008 | Sony PlayStation 2 Slimline Console
Disk wont spin
are you a cute blond? i give you alot of credit, but your going about it wrong.
1.you need to know if there is red/blue coming out of the laser.
2.is the laser focusing (moving up and down)
3.the spindle height has to be at the correct height for the laser to read the disk (thus spinning it) and the spindle also had had problems with this unit. (you can clean it up )
4. once it spins the disk it has to read the TOC (table of contents)which means it has to move to the inner most part of the cd
5 send me you name address and if your busy friday! lol
Feb 07, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 slim line
if the laser is moved to the middle of the area and when you first turn it on it doesn't go back to starting possession's then some thing is wrong with the motor drive more than not it's likely you have a crack in the board.
Jan 03, 2008 | Sony PlayStation 2 Slimline Console
Ps2 game disk wont spin
you should buy one of those laser disks to clean the laser and inside of the ps2 so it will work again cause mine had same problem and i used that and after it worked
May 04, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
