Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Not feeding paper copies from adf
When i put tha paper copy to be copied it only pick up one paper
    Problem Solver:
  • 5 Answers
The add toner light suggestion is correct, because it is telling the machine to only do single copies.
Do NOT use alcohol on pickup rollers. This will only dry the rubber out and cause it to fail sooner. It is a very short term solution since it does clean some dirt off the roller, but does a lot of harm.
If a rubber roller is not picking up paper and the clutch appears to be ok, you can clean the roller with eucalyptus oil (4 oz bottle at health stores for about $5) using a cloth. Try to scrub the rollers all the way around until they are clean (especially the leading edge that starts the gripping of the paper). Be carefull that you do not damage the clutch while turning the rollers. Sometimes you can get assitance from the machine by stopping it in a cycle, or taking the back or top off and tripping the clutch. If the rollers leading edge is shinny, use a piece of course sandpaper (60 to 80 grit) and barely roughen the surface of the rubber roller, then clean it again with eucalyptus oil. The roller will be as good as new and in some cases better than new.
Posted on Jan 23, 2008
  • 208 Answers
You need to clean the rollers.
Here is a trick. Take a piece of paper, and put rubbing alcohol on it across the front. Dampen it don't soak it.
Place the paper in to the feeder and hold it so it will not feed all the way in.
What you are doing is spinning the feed rollers on the alcohol dampened paper, It will clean the rollers well.
Once you get the feed rollers clean, dampen another sheet and let it feed through several times to clean the remaining rolls.
That should help a lot. Just do not soak the paper. put alcolon on your fingers and spread it across the front of the paper about 1-2 inches. You will be surprised how much dirt will come off.
Posted on Nov 29, 2007
  • 33 Answers
Is the add toner light on if it is it will only make one copy @ a time.
Posted on Nov 03, 2007
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
Copy off glass copy is good. copy from ADF copy is blurry
The problem is either dirty glass for the ADF which you can clean, or the ADF cannot feed the paper you are trying to scan through accurately. Most smaller all in one printers use the same scanner element for both the ADF and flat glass scanning so the fact that glass scanning is fine points to the two problems listed above.
Mar 29, 2011 | Office Equipment & Supplies
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
The feeder in my office copier is not feeding the paper thru it. It only copies if you manually put it on the glass.
Hi, you need to open the adf cover, check for any leftovers of paper or clips, or... also clean the pick up and feed roller with alcohol by piece of fabric.
Also have on mind that the feeder is only for plain paper usage.
Sep 08, 2010 | Canon imageRUNNER 1023iF Black and White...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
It senses paper loaded into the ADF but doesn't feed
There should be a button with settings on 2 sided, collate, etc. There should be an option to change paper settings.......or just clear the whole menu, and go to default to reset the rollers.
Oct 19, 2009 | Canon PC-980 Color Copier
Our HP laserjet M2727nf does not feed the paper to print anything
just clean paper pick up roller whit wet cloth or can do this for ADF pick up rollers too if someday have the same problem whit ADF. Good Luck!
Oct 05, 2009 | HP Laserjet M2727nf Multifunction Printer
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Will not copy
If the paper isn't feeding in the ADF (automatic document feeder - upper paper feeder) then the ADF roller assembly will need to be replaced. Try a copy on the flat glass area. If it work, then it's the ADF, If not then the upper scanner assembly with have to be replaced.
Apr 28, 2007 | Canon imageCLASS D880 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
