Question about DNP DS40 4X6 - 6X9 Color Dye Sub Printer
White border on two sides - DNP DS40 4X6 - 6X9 Color Dye Sub Printer
White border on left side of screen
Try restarting the computer, and
1: see if that fixes it
2: while the computer is restarting (and you see the manufacturer's logo, etc.), do you see the white border? If so, it's probably a setting on the screen. Check if there are buttons on the screen/monitor to get to a menu of options; see if you can fix it there.
Mar 24, 2013 | Acer Aspire One PC Notebook
I have an Accubake stove and the metal border around the knobs needs replacing is that something that can be done?
most likely, enter model # on sears website and locate the part # order from them or take the part # to your local appliance part store or call the local store directly. Be sure to have the model # 1st.
Apr 14, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Border in each column
Follow this steps to achieve that.
  1. Click on the column you want to have a border, On the Page Layout menu click Borders
  2. On the Borders and Shading window go to the Borders tab not the Page Border tab
  3. Select the borders you prefer then on the Apply to: drop down select Paragraph. Click ok then your done.
May 12, 2010 | Microsoft Windows XP Professional
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
White border on edge of print
The only way would be to use a bigger piece of paper and cut it down to the size you need...... The copier will always leave a white border a round the edges.... It is done so the toner can be fixed into the paper with out off setting or jamming
Mar 14, 2009 | Kyocera Mita Office Equipment & Supplies
Image is partially cut off when printed
Your expert patiently talked me through several possibilities. Finally, in the print set-up window, I clicked on Properties in the upper right and made all my printing choices there. I still got a border, even though I didn't want one, but it was all the way around the photo...not on two sides, and the photo was not chopped off.
Aug 11, 2008 | HP Photosmart 325 InkJet Printer
Dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Apr 04, 2008 | Office Equipment & Supplies
DNP DS40 4X6 - 6X9 Color Dye Sub Printer Logo
43 people viewed this question
Top DNP Office Equipment & Supplies Experts
jasbo
jasbo
Are you a DNP Office Equipment and Supply Expert? Answer questions, earn points and help others
