Question about Brother HL-4040CN Laser Printer
Can't clear drum error. live tech support was interrupted.
  • 583 Answers
We got dissconnected but i have put up the reset procedure on that session.i will explain here.
to clear drum error:remove the drum then reinsert,then-- Reset the drum counter. With the front cover open, press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.this will reset drum counter
Posted on Jun 19, 2009
  • livetech Jun 19, 2009
    you can rate the chat session succesful too--as you hve not yet rated it after the solution.thanks in advance.
Hi this is atul, with whom u was having chat. plz have chat session with me. i knew the solution.
Sharp A5518 - Error Code H2, copier not working
h2 - thermistor error
press
# - Interrupt - Clear - Interrupt
then
14
then
press start
Mar 25, 2015 | Sharp Office Equipment & Supplies
Drum error code
Hi, drum error codes in digital sharp copiers are non-existent. May be drum error symbols or display messages on touch screen types. They differ depending on model but the most common is reset code 24 sub 7 for example sharp 5015 you rest by pressing; C,Interrupt, 0, Interrupt keys and then inputting the above keys. You may specify your copier model.
Dec 14, 2011 | Sharp Office Equipment & Supplies
I need to reset copy counter after changing Drum unit on Sharp AR 161 photo copier
Perform the following procedure to enter the simulation mode."#" key Interrupt key "C" key Interrupt key, then, then enter 24 start 7 start, then you can clear the drum count.Press 42, start, 01, start for clearing developer counter, and after clearing all this you have to press 'ca' to exit this mode, rate this and vote for this.
May 17, 2011 | Sharp AR-160 Copier
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
How do I clear F2 and H4 on Sharp photocopier
F2 means wrong cartridge installed, could be a bad cartridge. H4 is a low fuser temp error. try resetting by pressing "#","interrupt","C","interrupt. then press"1","4","start". then turn off/on and see if it clears. if not you will need a tech.
Nov 12, 2009 | Televison & Video
Sharp AR C160 - Error H4-00
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
Hope that helps...
Lbcoaster
Sep 16, 2008 | Sharp AR-C160 Color Copier
Error h200
H2 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
enter 14,
Hope that helps...
Lbcoaster
Brother HL-4040CN Laser Printer Logo
1,215 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
