Question about Samsung Galaxy Tab 2 7.0
My tab totally off....
Please help me...when i push volume down button then push power off button to off the screen..when i turn on again it's doesn't work and totally off..please help me to fix it.
    Scholar:
  • 178 Answers
Please describe more , you say when you press the volume button down then push power button to turn off screen, then you turn on again , and it doesnt work , what doesnt the phone or the function
Posted on Apr 22, 2014
  • 3 more comments
  • Stu Morris K Apr 22, 2014
    Sorry the tablet or the function does not work
    What OS is the tablet running
  • hardi priyanto
    hardi priyanto Apr 23, 2014
    the tab can't on...it's died...android 4.1...thanks
  • Will Godwine Apr 23, 2014
    Is the power button stck in the down position or does it release to a normal position?
  • Stu Morris K Apr 23, 2014
    How old is the tablet
How do I reset this tablet
Since model number you wrote is for kickstand I assume that you want to reset Galaxy tab 3
Please make sure you have backed up all of your important data and apps before performing a reset.
Turn your Galaxy Tab 3 off.
Press and hold the Volume Up, Power and Home buttons together until you see an Android lying on its back. This is the - stock recovery screen.
Use the volume keys to scroll down to Wipe Data/Factory Reset and use the Power button to confirm.
Scroll down to Yes, Delete All User Data and hit Power to confirm.
Back on the first screen, scroll down to Wipe Cache Partition and select with power button.
Hit Reboot System Now to restart your Galaxy Tab 3 with factory settings restored.
Oct 15, 2016 | Tablets & eReaders
How do I turn on my pandigital supernova tablet?
It could be two things, Jack: I would start by plugging it in to your charger for about 24 hrs to make sure it's not just the battery after that length of time not being used...OR, you might have to reset it to factory settings.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults.
First you need to make sure your tablet is powered off.
Hold down on the Volume + button and hold down the Power button at the same time.
  • As soon as the tablet's screen turns on, let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
  • At this point you will see a screen with boot options.
  • Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
  • On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
  • At this point it will be going through the wiping and resetting process.
  • When it's done you will see the first screen you came to when you first started the setup.
  • Just tap the Power button to select Reboot System Now.
Stuck in Android System Recovery Tips to Fix Recover Lost Data
Apr 27, 2016 | PANDIGITAL SuperNova
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
Can my son's forgotten password on his Zeiki tablet be manually overriden?
You have to reset your tab its at the back of your tablet .or you may go nearest service provider to unlock it.if is not working go to unlock account enter your user name then choose pattern enter your new pattern and then enter it again for confirmation..or u shut down the device then hold the power button hold again the volume up and the power button together.you see the recovery mode scroll down the with volume down button press the factory settings using the power button..then press the power button again to reboot make sure your battery is fully charge.
Apr 25, 2015 | Tablets & eReaders
Maxwest tab-9155 won't load past android screen
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 24, 2014 | Tablets & eReaders
Samsung tab 3 frozen on the on screen. code 10 fault code
Forcing a complete Reset works. This option keeps all your existing data.
  1. Hold Volume Down and Power button until presented with two icons (Open box and an arrow and an Adroid Doll)
  2. Select the left option.
  3. Volume down to toggle between options. Volume up to select.
  4. Will be presented with the Recovery Console.
  5. Select the first option "Reset"
  6. Here the volume buttons are used to navigate up and down and the power button to select.
After selecting the reset option your Galaxy tab will fully boot up again..
Feb 16, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
How to reset my go clever tab r70
Had a similar problem with GoClever Tab R70 ; was also getting 'Ui Launcher has failed' Error ... Solved it by 1. Charging Tablet with USB power cable. 2. Using Bent Staple / PaperClip to press in reset Button at back. 3. Switch ON by Pressing and Holding BOTH Power On Button and Volume Up buttons together. This Boots up to a recovery Screen with a picture of Green Droid Laying Down with an Exclamation Mark inside a Red Triangle. 4. When you see this screen release buttons and again Press Power Button and Volume Up together to bring available options onscreen. Navigate Options with Volume Up and Down and Select by pressing Power Button. 5. If this doesn't work use paperclip /staple to reset and start again. 6. If there's nothing precious on your Tablet i'd recommend factory reset and to be doubly safe remove any microSD card that might have any data you want to keep. Thanks to this Youtuber for helping solve my Tab Problem : www.youtube.com/watch?v=jLgmptgKeNU
Mar 29, 2013 | Tablets & eReaders
My samsung galaxy tab 2 has a frozen screen I can't even turn it off help
Here is how you fix this problem: Hold both the power button AND the volume UP button down at the same time for about 5-10 seconds it should restart. You don't lose any info doing this.
Mar 26, 2013 | Samsung Galaxy Tab 101 Tablet...
My galaxy tab screen has blanked out and i cannot get it to do anything
option 1. Plugin in Power Cable Then Hold Volume down + Power button for 10 to 20 secs Your tab will Turn OFF. now turn it on using simple power button it shd work perfectly option 2. do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Mar 31, 2011 | Samsung Galaxy Tab Tablet PC
Galaxy p1000 is frozen cant switch off nothing is happening
Hope this helps:
How to Hard Reset Samsung GT-P1000 Galaxy TAB:
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Feb 05, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab 2 7.0 Logo
56 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
