Question about Konica Minolta Bizhub C454 Color Copier
Bizhub minolta 600 and 750
Hi worming up but the fuser is ready
  • Konica Minolta Master
  • 6,696 Answers
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
try this site for developer and drum as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 30, 2015
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
taminol
  • 62 Answers
SOURCE: minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Posted on Jul 27, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
How do I reset the fuser AND PF (PAPER FEEDER) part life
1) Press the 3 and 9 buttons at the same time in the ready status.
2) "Reset Menu" will appear on the LCD. Scroll to Fuser by pressing up arrow or down arrow button then press the OK button.
3) "1. Reset 2. Exit" appears on the LCD. Press the 1 button to reset the fuser counter. The display briefly shows "Accepted".
The machine returns to the ready status after a few seconds.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 07, 2014 | Brother MFC-9120CN - 17 PPM Multifunction...
MITA TA180 ERROR MESSAGE C6000
Fuser heater break
70°C/158°F for 10 s during warm-up and
ready in.
During warm-up, the temperature at the
fuser unit thermistor 1 does not rise by
1°C/1.8°F continuously for 5 s.
Fuser thermistor 2 detected less than
ready in.
fuser unit thermistor 2 does not rise by
Defective fuser
heater 1 or 2.
Replace the fuser heater 1 or 2.
on fuser
thermistor 1 or 2.
Defective fuser
thermostat.
Defective PWB. Replace the power source PWB or engine
Jan 08, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
Two images appear on copies in both text and
Hello sir; It seems like drum blade worm out need to replace also possible fuser roller worm out too ,my suggestion is replace both of them.
Nov 06, 2009 | Lanier 1205 Copier
E 005
A E005 is saying the cleaning web needs to be replaced or the web counter needs to be reset...If the cleaning web is out it will cause more damage to your upper fixing roller
Jul 28, 2008 | Canon NP 6050 Copier
Brother MFC 9030
Open the printer and check to see it your fuser is worm up. Do not touch the fuser. If it is cold. you have a problem.
You fuser may be at end of life. Need to be replaced.
cost price of fuser and labor will come close or above cost price of machine. your choice.
Good luck
Jul 24, 2008 | Brother International Plain Paper Fax
Paper jammed
Your fuser is bad. The fuser is a part that "fuses" the toner with heat and pressure to the paper. You will have to have a new fuser to fix your problem.
Jun 23, 2008 | Samsung ML-2510 Laser Printer
925.01 service fuser error
Hi The Fuser has failed meaning the temp of the fuser is to high or to low. In order to fix this error you can try powering down the printer for 10 to 15min and retry . I think though you will have to call for service or replace the fuser yourself!!! I hope I have helped.
Dec 06, 2007 | Lexmark T642 Laser Printer
Konica Minolta Bizhub C454 Color Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
