Question about Samsung Admire SCH
Phone blinks on and off and won't turn on
Phone shutdown. turned on shortly. then started blinking on and off and won't come back on. What should I do?
3 Suggested Answers
SOURCE: Samsung Nimbus - Wont boot up, is looping intro
plz switch off the mobile and remove the sim and replace it on to another mobile.
If the same problem persists
log on to the fixya website
and towards ur right hand side there is a samsung user manual
click on it and follow the instructions as given in it.
Posted on Feb 01, 2008
second2dlast
  • 61 Answers
SOURCE: phone keeps blinking, will not stay on
This may due to the moisture accumulated inside the phone. Kindly open the phone casing, take out the battery and let it sit on room temperature.
have you tried turning the phone on with its adapter plugged? it may also be caused by a low power source. your battery might need charging.
otherwise, do consider replacing your battery.
Posted on Jan 15, 2009
Sony Trinitron KV32HV600 won't turn on
that was mean the high voltage shutdown, check the power supply regulator and the horizontal circuit if has shorted component.
Jul 21, 2012 | Televison & Video
Tv just went off in use. Power light blinking, will no turn back on
Set is in shutdown as a short somewhere.
If model indicated here is correct someone has to open it and check voltages in power supply first.
Apr 01, 2012 | Toshiba 36AF43 36" TV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Tv won't turn on and the light is blinking 7 times
Hello
Check the power supply section for any loose solderings. Resolder all suspected solder points by applying a little more solder, without making a solder bridge short in between close solder terminals. OK.
Oct 21, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Model kp-53xbr4ct made 1998. picture was good. sudden went to center of screen and bowed up and down from center. it hade sound. turned of, now no sound. stand by flashes 6 times. unplugged , plugged back...
the video color distortion with the bowing in the center is called a convergence failure. the 6 blinks indicate a power supply shutdown for high voltage protect. the 14 blinks is just the tv trying to turn back on. you may be having to problems with the convergence and the 6 blinks or it may be related because the convergence amps can cause shutdown if they are shorted. i suggest calling a serviceman per the possible tow different failures. good luck
Jan 12, 2011 | Sony KP-51HW40 51" Rear Projection...
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
My misubishi
Good day, fidel509; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Good luck, I hope this will get you started in the right direction, big IRISH.
Jul 18, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
May 18, 2008 | Philips 55P8341 55" Rear Projection...
Tv want go on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
VS50607 Mitsubishi
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.....
Sep 24, 2006 | Mitsubishi VS-50607 50" Rear Projection...
Samsung Admire SCH Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
