Question about Cycling
No power for cateyey erogciser model EC 1500 - Cycling
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
I have a Friden Model 130 Electronic Calculator and am interested in its current value?
Dear workmangk. I have a working EC 132. Your EC 130 was the 1st solid state calculator. My father used to sell & support them. I estimate a working model could be worth $US1000 +. I bought my non working EC 132 for around $400 some 8 years ago. They are difficult to obtain now. Best wishes, Gordon. Adelaide. Australia
Jul 21, 2011 | Computers & Internet
Need an operator's manual for a tb146 ec tiller
I believe that the tb146 ec is a Troy-bilt tiller, so you need the model number and the serial number to get the manual. Go to http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Then enter the model and serial numbers and click Search.
The plaque with these numbers is usually on the outside of the tine housing. It's generally in a spot that won't get damaged while the unit is in use.
I hope this helps.
Jul 08, 2011 | Garden
Need new cord model EC - 12TWT4 Where we buy part store?
I just found this site when looking for parts for my EC-12TWT4. I haven't dealt with them before however...
http://www.vacshopusa.com/sharp_parts_supplies.htm
Aug 10, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
I have a 2001 Vulcan Classic 1500 and I need to know exactly what type of oil and weight of oil I need to use for a complete oil & filter change?
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. If in a hot area like Texas or New Mexico go with 20w50. Definitely change the oil filter.
A “very helpful” rating on this answer? Thanks!
Jul 04, 2009 | 2001 kawasaki VN 1500 Vulcan Classic...
Mitsubishi inverter
mitsubishi fr-520s-02k-ec inverter drive.
Keep flashing a P5 code and will not reset. With the rest button.
How do I reset
Jun 06, 2009 | Xantrex Technology Ags Harness Cable...
Code EC appears on my washing machine few seconds after started
Ec indicates a problem with the thermistor or temperature sensor.
Repair and service your own washing machine.
kindly check them out....
thank you have a nice day
Jun 02, 2009 | Samsung Washing Machines
Ihave a panasonic projection model pt ax 100u
everything you need to know here... http://www2.panasonic.com/consumer-electronics/support/Televisions/Home-Theater-Projectors/model.PT-AX100U-EC
Jan 04, 2009 | Panasonic PT-AX100U-EC DLP Projector
Cycling Logo
26 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
