Question about HP PSC 1510 All-In-One InkJet Printer
Reset ink levels hp 1510 - HP PSC 1510 All-In-One InkJet Printer
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
  • 21 Answers
SOURCE: How to reset the ink level for a HP 60 ink cartridge
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Posted on Jul 06, 2009
  • 6 Answers
SOURCE: reset ink level on hp 6310 #98 cartridge
if you are using a refilled catridge you would not get ink levels right.
if you want right ink level use genuine ink catridges.
you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
Posted on Aug 28, 2009
SOURCE: Deskjet f4185 reset ink level...
for colored is only 3ml and the black is 8ml
Posted on Apr 28, 2010
  • 420 Answers
SOURCE: how to reset ink levels from HP J4580 printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Posted on Sep 15, 2010
Can't install ink cartridge
Here is a link to an HP Video on how to change the ink cartridge (the 1510 is the same procedure as the 1512).
http://support.hp.com/us-en/product/HP-Deskjet-1510-All-in-One-Printer-series/5157551/model/5385180/videos?cc=us&lang=en
Nov 02, 2015 | HP Office Equipment & Supplies
How do I insert Ink Cartridge into HP Deskjet 1510. Do I need to have 2 cartridges inserted. Only use Black.no other details
Dear
You can follow the link. Yes you do have to install 2 carts. to work the printer. However from printer setting you may disable color print.
Note Ink cart head gets clogged when not used prolonged time.
Thanks. Replacing Cartridge HP Deskjet 1510 All in One Printer
Mar 05, 2015 | HP Deskjet 1510 Allinone Inkjet Printer...
Refill
You have to reset the cartridge chip with a special device that resets the stored ink state data.
Jan 26, 2014 | HP PSC 1510 All-In-One InkJet Printer
HOW DO I CHECK THE INK CARTRIDGE LEVELS HP PSC 1500
You can check it on the settings>Ink levels on the printer software
May 14, 2011 | HP PSC 1510 All-In-One InkJet Printer
I have an HP PSC 1510 and i ran out of ink... i have black in my drawer and no time to get color ink, how can i get my printer to work with out color ink?
You can not. The printer will not work without the color ink. Please Stop by your local supply store and pick up the color ink.
Dec 08, 2010 | HP PSC 1510 All-In-One InkJet Printer
How to change ink cartridge on hp psc 1510
Hi, Please check this link: http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Refer to pages 43-48 (printed number on the page or pages 46-51 in the PDF page guide)
Hope this works for you.
Cheers, Ed
Nov 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do i get the ink levels on my HP PSC 1510 All-in One printer?
Go to start, parameters, printers chosse the printer click right mouse button properties....usally you will everything there
Feb 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
Ink lvels
Hello holliston,
You can try the following steps that should help you determine your ink levels.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining. Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Sep 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Ink levels
Open the printer preferences, click on the services button, locate "Ink Levels" and voila!
Mar 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
148 people viewed this question
Seeker5211
Seeker5211
