Question about Dell 5130cdn Color Laser Printer
BLURRED PRINTING ON DELL 5130 IT LOOKS LIKE THE IMAGE PRINTED TRICE ON TOP OF ITSELF BY SLIGHTLY MISALLIGNED- HOW CAN I FIX THE PROBLEM
2 Suggested Answers
  • 28 Answers
SOURCE: dell 1710 printer. When printing just tthe top 2
Have you tried replacing the drum? That is the part that the toner cartridge actually sits in.
Posted on Jan 29, 2010
My laserjet printer started making load noises and no longer prints-the last thing printed only printed the top 3inches and then was all black, it then stopped working altogether
Use the following checklist to ensure that the print cartridge is still operable:
  • Ensure that the print cartridge is seated properly.
  • Inspect the print cartridge for remaining toner.
  • Check the expiration date stamped on the print cartridge box.
  • Check the print cartridge to see if it has been disassembled or refilled.
  • Inspect the print cartridge to see if toner is leaking through worn seals.
  • Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
  • Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
The HP LaserJet 1100 series printer cannot print to the edge of the paper, to get the image to fit into this printable area, slightly reduce the size of the image.
try this and let me know, also check the status of the toner.
mail me- raaj_k001@rediffmail.com
Jan 12, 2011 | HP LaserJet 1200 Printer
Blurred printing at the x offset
Print head is not aligned properly . You need to adjust heating plate on head.
Aug 02, 2010 | Evolis Dualys ID Card Printer Smart Card...
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Printed image repeats later
I have a Dell 5100CN, and believe that this problem is caused by the drum not releasing the full charge which holds the ink in place on the drum until the page is printed. After the image is transfered to the Drum, the 'Fuser' unit heats up the paper and pressure forces the paper against the drum to transfer the toner from the drum to the paper.
Since the Image is printing, and you are getting a ghost, I guess that the problem is most likely the 'Pressure Roller' or 'Heater' in the 'Fuser' unit.
Buying the Fuser unit from Dell could cost you around $200 from Dell, but I just found one on eBay for $129 Got to www.ebay.com and search for item number 190388919845
I highly recommend that you buy a new OEM (original Equipment Manufacturer (Genuine Dell)) 'Fuser Unit'
Good Luck
Apr 23, 2010 | Dell 3010cn Laser Printer
Double printing or 'ghost' images
you need to change your toner opc drums
Dec 13, 2009 | HP LaserJet 1020 Printer
We have installed new ink cartridges. the printed page is basically a "ghost" image or occasionally a "blurred" printing. what did we do wrong? we even removed the new cartridges to see if they were...
In this case you can try out the alighnment process..
It works most of the time.
and also try to clean the carriage with a lint free cloth and the copper contacts as well..
then try to print.
Nov 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
Blurry printing on laser printer
You have a bad drum. Return the drum for a replacement and you should be good to go.
Armymason
Apr 01, 2009 | Brother HL 5250DN Laser Printer
Dirty smudges when printing
try to go to the enternal part of your printer and check if theres an inks.. or try to check on the set-up if you have a clean printheads... try running it again...
Jun 12, 2008 | Canon imageCLASS D680 Laser Printer
Blurred bands in prints
Try changing ink cartridge. Print only "grayscale" and if that happens, you need a black cartridge changed. If, not color
Mar 16, 2017 | HP DeskJet 460WF Mobile Color Printer
Dell 5130cdn Color Laser Printer Logo
50 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
