Question about Black & Decker DW713 10 In. In. Comp Miter Saw
Reset switch on dw713 - Black & Decker DW713 10 In. In. Comp Miter Saw
Product just arrived, saw is stuck in cutting position
There is usually a safety or transit lock or pin which is engaged to lock the saw down for safety and for a more convenient way or transporting it.
The ones on my saws are a simple ball-headed pin sited close to the hinge of the saw which can be easily withdrawn once enough downward pressure has been applied to the saw to overcome the return spring pressure.
Mar 15, 2015 | Dewalt DW713 NA 10" Compound Miter Saw
How to take off the pin that hold the ajustment lever on a DW 713 Dewalt Miter saw ?
I would use a hammer and a smaller diameter punch than the pin. Take a few wacks and see what happens. If it is rusted soak it with something like liquid wrench over night.
Oct 07, 2014 | Dewalt DW713 NA 10" Compound Miter Saw
My chop saw has power but does nothing, it's new. Brushes are good, Power to the switch but it does nothing.
Hi. Maybe there is a safety interlock of some sort for which the conditions are not being met, maybe a blade guard switch or some such. Can you refer to the owners manual?
Sep 14, 2011 | Black & Decker DW713 10 In. In. Comp Miter...
WENT TO BUY A DW713, AND NOBODY KNEW THE CORRECT PROCEDURE ON HOW TO CHANGE THE BLADE
sjacquesjr-
I own the dw713 - it a good saw.
To change the blade, first unplug the saw. Bring the blade guard all the way up. When you do you should see a black star drive bolt on the left side of the blade housing, toward the front. This bolt must be loosened far enough to allow the guard to rotate up far enough to expose the bolt holding the blade to the arbor. With the guard out of the way, press in the arbor lock on the motor housing (its a black or gray button) while slowly turning the blade. You should feel the arbor lock engage and the blade no longer turn. The rest of the steps you have to do while holding this button in...an extra set of hands would help about now. Using the wrench that comes with the saw (its mounted at the back, near the dust port), unscrew the arbor bolt. The arbor bolt is reverse threaded to match the blade rotation, so it will be counter-intuitive when screwing/unscrewing this bolt. To unscrew, push the wrench away from you. To replace the blade, just reverse these steps. When putting on a new blade, don't forget to orient the blade teeth in the direction of rotation. Happy cutting!
If this has been helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
May 05, 2011 | Garden
My black and decker miter saw is plugged in and will not work. I just used it yesterday and it worked fine without any sign of problems. What could be wrong?
Make sure something else works where it is plugged in.
There may be a small thermal reset button you have to push, near the motor.
The switch could have gone bad, because they have that extra safety you have to push. Check for 110 AC at both sides of the switch when pressed.
Aug 10, 2010 | Black & Decker DW713 10 In. In. Comp Miter...
Where can i find a users manual for a black & decker miter saw 1710. manualsonline does not have it.
I found an online manual. I hope it's what you are looking for.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/387479-00,1710.pdf
Mar 09, 2010 | Black & Decker DW713 10 In. In. Comp Miter...
I need to know how to change the blade on a Black and Decker 1710 Type 2 10'' Miter Saw.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in the model number 1710 and it will go to another page requesting either a breakdown or instruction manual, you have to use the manual for a type 4. They do not offer the type 2 as an online version. Hope this helps
Mar 30, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Black & Decker DW713 10 In. In. Comp Miter Saw Logo
24 people viewed this question
Top Black & Decker Saws Experts
Ruben Bustamante
Jason
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
