Question about Dewalt D51822 Clipped Head 2Inch to 312Inch Framing Nailer
Air leaks in head - Dewalt D51822 Clipped Head 2Inch to 312Inch Framing Nailer
I have a, sanborn black max compressor builds up to about 30psi but won't go higher. will hold that when shut off. couldit be a check valve?
If it were the check valve, (safety release valve), you would hear the air escaping from the safety release valve. You have an air leak somewhere. A small leak in the system will keep the compressor from building pressure. If you turn the compressor on and feel around the ends of the tube that leads from the compressor cylinder head to the tank (be careful... it will be HOT) you may feel air escaping from the tube connector at the tank or the connector at the compressor cylinder head. If that is the case, tighten the connectors at the compressor head and the tank. If the connectors still leak, you will need to remove the tube and replace the packings (gaskets) at each end of the tube. Also check all of the hose connectors for leaks, and check the hose for damage that may cause an air leak. If you remove the air hose from the compressor and run the compressor you will be able to tell if your problem is in the hose or hose connectors or the compressor-to-head air tube.
Feb 13, 2015 | Air Tools & Compressors
My Air compressor Dich. temp shows high temp....what are the reasons for the same.....
High temperature discharge air is caused by leaking reed valves or leaking head gaskets. Another indication of leaking head parts is that it takes longer to fill than usual or the compressor will not reach cut-out pressure. Good luck
Dec 06, 2014 | Air Tools & Compressors
Why wont my steelcraft 13 gallon 5hp model ta25 build up no more then 20 pound of pressure and all i did was change the oil?
Check all connections for air leak including the water drain valve with soapy water. If no air leaking from connections, spray soapy water on head area where head attaches to the cylinder checking for gasket leaks. If no leaks are found, most likely problem is in the head /valves /internal gasket leak. If head gasket or valves are leaking, you will notice that air seems to blow out of the intake filter (normally there is good suction at the intake). Good luck
May 16, 2014 | Air Tools & Compressors
My black&decker electromate 400 compressor runs but will not build pressure
Mark:
There is an air leak in the system. check the easy stuff first. let the compressor run, and carefully feel around the ends of the tube that runs from the compressor cylinder head to the tank. You can sometimes feel where the air is escaping. You can also squirt a soapy solution on the ends of the tube and look for bubbles or pressurized air blowing the fluid back in your face :-).
When you find the leak, you will know how to stop it. Also check the drain valve at the bottom of the tank to make sure that it is closed and not leaking. Check your hose connections for leaks... remove the air hose and run the compressor.. if it builds pressure, your hose connections are leaking. The harder stuff... Take the shroud off, check the head bolts for torque and the head gasket to see if it is blown, (Use the soap solution). The really hard stuff... If you have found no leaks, the valve body or piston ring(s) are the problem. You'll need to pull the cylinder head and replace the valve body or piston or piston rings.
Good luck
Sep 14, 2013 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
Compressor starts and stops hot air
bad regulaor or thers a leak on the cylinder head . does it take a long time to reach pressure. if at all. sounds like a leak on the head replace diaphram or check and see when you start it if air is leaking around the head.
Apr 18, 2013 | Ford Taurus Cars & Trucks
Rn46 bostitch nailer leaks
This problem is caused by air leaking past orings in the head valve. Remove head and pull out the head valve. The metal surface on the head where oring makes contact should be smooth and oring should fit snugly. Of scratched or deep groove, or if oring is worn, the gun will not fire (sand with very fine paper or replace head). Also examine the headvalve where smaller oring makes contact. If small scratches are visible, remove with very fine paper or replace. To test if head valve is the problem, remove head and headvalve and apply plenty of white grease where orings make contact and replace head then test. If the gun fires, air was leaking past the orings. Good luck
Jan 29, 2013 | Air Tools & Compressors
Air leaks when triggered and no nail
Make sure no nails in gun. With air connected listen for leaking thru nose of the gun also. If leaking thru nose slightly, air is getting past the cylinder seal oring and/or top of cyl is not seating against headvalve. Repair leak to nose of gun before trying to fix head leak. With no air leaking thru nose of gun, add plenty of white grease to orings in the head (one oring at a time) to see if leak is less and/or grease will streak behind the leaking oring. Then repair as needed. May need slightly thicker oring or sand surface where oring makes contact to remove scratches that are allowing air to pass. Also air can enter the head thru the small port in the gasket leading to the head (make sure that the gasket is sealing).
Nov 05, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
I have a Central Pneumatic, 21 Gallon, 3HP air compressor. The compressor is exiting air through exthaust port.
If air leaks when motor is off, fault most likely in-tank check valve. Follow discharge air line from pump to tank. Brass/steel valve at tank is the check valve. Remove hose to valve and check for leak. Replace as needed. If air is leaking while motor is running fault could be reed valves in head. Faulty reed valves in head, or torn head gaskets will cause very hot discharge air and tank will most likely never fill to shut off (or take a very long time to fill)
Sep 06, 2010 | Air Tools & Compressors
Hi, i got a hitachi nv45ab and My nailer leaks air out the back
Hitachi nv45 series is the most popular line of nailers amoung professional roofers. There are three areas that develop leakes. Leak out head vent indicates cylinder stuck in lower position or headvalve worn. With air connected, gently rap head of gun against rubber mat to move cylinder to position. (Use caution not to damage head). If this action works, gun needs cleaning internally or lack of oil. If air still leaks out vent remove head and examine valve in head and replace as needed. Check that cylinder moves freely up/down (travel aprox 1/4"). If cylinder is hard to move pull cylinder and clean replacing orings as needed. If leaking around trigger, remove rollpin and trigger and check nylon ball for pits and replace as needed. If leaking around base of gun check for loose bolts and/or worn gaskets. Remove nail canaster to check feed piston gasket and screws. Good luck with your repair and post again if you have other question.
Aug 04, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
Mar 12, 2009 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Dewalt D51822 Clipped Head 2Inch to 312Inch Framing Nailer Logo
96 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
