Question about Westinghouse Electric SK-32H570D 32 in. LCD TV/DVD Combo
Sk-26h570d tv/dvd combo has sound picture goes out
Had sound & no picture. Replaced backlight inverter board. now screen flips on & goes blank almost immediately, still have sound. Blue indicator light at bottom still on.
LED Backlights on LG TV?
If audio is OK, the backlight inverter is the part should suspected. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 25, 2015 | LG Televison & Video
Tv has picture for 3 seconds then goes blank. Sound is good.I was told that the backlight or inverter boards were bad so I replaced both of them still not working.Can someone please offer some help.
There is a flat cable coming from the bottom of the screen and ends in a circuit board usually under a metal cover. This board is the problem. You can get a replacement at:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 26, 2015 | LG Televison & Video
I have a LG M2262DL LCD TV/Monitor. When I switch it on I initially have a picture and sound. Usually within seconds the screen goes blank but the sound is good.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 08, 2014 | LG Televison & Video
Rca tv powers up has backlight no sound or picture replaced main board and inverter
I would check the input board for correct power supply input
check the blue 15pf 6kv caps near the output from the PSU to the inverter.
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Video comes on but I lose the picture in 3-5 minutes, screen goes blank.
U still have sound,when screen go black?Than ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 17, 2010 | Vizio L37 Television
When i turn the t v on i get maybe one second of picture and the screen goes black but i still have sound
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board.U will get picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 15, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Screen goes black when i turn it on but can hear sound
Ur LCD inverter backlight board it dead.Replaced this LCD inverter backlight board will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight for the replacement.
Mar 13, 2010 | Vizio L32 32 in. LCD HDTV
Screen "Flashes" on/off
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 12, 2009 | Toshiba Satellite A135-S2276 Notebook
Westinghouse Electric SK-32H570D 32 in. LCD TV/DVD Combo Logo
20 people viewed this question
Top Westinghouse Electric Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
