Question about Olympus PEN EPL1 Digital Camera
It's not working because it's displaying "Write protect"
When I open the cam it writes immediately on the screen " write protect" and can't take pictures
josh1856
  • 105 Answers
SOURCE: write protection
could be a couple things.
first: your memory card most likely has a slide switch just switch that back to the unlock mode
second:
second: from olympus guy
put the camera into play back mode. This is where you can see your picuters on the camera. Then go into the menu and try to go to card setup. This is 3rd tab. So hit ok hit right for mode menu. then hit down to you see card setup. Then hit right arrow 2 times and you will see formatt. Then go to yes and it will say caution somthing. and hit ok
Now if you have picuters on the card this will delete them so if you care about them you might want to think about data recovery. But if not try this and let me know.
"""I don't use the camedia software to download pics from the camera, neither do I use Xp's picture and scanner wizard. I simply plug my cam to the usb port and xp detects it as a USB mass storage device. I then copy the pics from the removable device displayed on My Computer window. Would you say that this method is not safe?""""
This is best way to do it i think. If you dont want to go into Cameida. The xp scanner camera wizard works good most time i dont know why it messes up some camera cards and its really random. One thing i would say. Formatt the card everytime you download your picuters. Not in the computer by right clicking on the driver, NEVER DO THIS!! will blow your card basicly. Do not delete pictuers from you computer with camera pluged it. Basicly most cameras us a diffrent file system the your computer. So that can start to mess things up. Just put the card into camera and do a format.
hope that helps.
Posted on Jan 31, 2008
  • 4 Answers
SOURCE: write protect written across screen,will not allow me to view or take pictures,why??
try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Posted on Sep 28, 2008
SOURCE: Camera says "write protect" and I can't figure out what happened.
my chager to my jazzcamer hdv178 dose not work where can oreder another one?
Posted on May 18, 2009
SOURCE: unwrite protect olympus Fe 280
go to set up and reformat. This will fix the problem
John Harlow
Posted on Jun 26, 2009
SOURCE: i can't use my cam (olympus fe-340),"WRITE PROTECT" is shown
ur memory card is write protected...theres this lil switch on the memorycard jus flip it the other way n ur good as new
Posted on Jun 15, 2010
Write protect is on the screen
Remove the storage card from the camera and look for the Write Protect switch on it. The switch will usually have a locked and an open padlock symbol. Ensure that it is set to the open, unprotected setting.
Mar 28, 2014 | Olympus Cameras
When i open my camera it shows write protected from after i connected to my computer. can i fix it my self.If ican then how?\
Write protected means the you can only see but you can't add anything to it, in this case it would be your SD card.
Try checking your memory card, there should be a kind of switch on the side, if there is, it must be on "Lock", just slide it up or down, depends on where the lock section is. Try it again.
If it doesn't work, then you must go to the camera's properties, and unblock from here, also make sure the read and write boxes are checked. Goo dluck and hope it works.
Oct 27, 2013 | Olympus LCD Screen Display FE-320 FE-340...
I have GE E1480 W Digital Cam. How to remove the write protect?
take card out of camera on the side there's a small switch which is locked if it's moved to the locked symbol, just move to the unlocked symbol.
http://www.youtube.com/watch?v=58pdnjskvyw&feature=related
Mar 09, 2012 | Cameras
Olympua m 760 cant take pictures screen says write protect
Your memory card has been write protected.This can be very easily fixed.
  1. Turn off cam.
  2. Take out the mem. card. (it's probably located near the battery. press down on it and release it. it will pop out.)
  3. Slide the small switch on the side of the card to the position marked with an unlocked padlock.
  4. Put card back in and turn on cam. Done.
Apr 25, 2011 | Cameras
HOW TO FORMAT A WRITE PROTECT USB DRIVE?
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
write-protection-registry
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
disable-write-protection
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Aug 15, 2010 | Kingston Technologies 512MB DataTraveler I...
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
I can't use my cam (olympus fe-340),"WRITE PROTECT" is shown
Jun 07, 2010 | Olympus FE-340 Digital Camera
Unwrite protect olympus Fe 280
John Harlow
Jun 20, 2009 | Olympus FE-280 Digital Camera
Card Reading Write Protected
hi there
some card do have a physical lock onto itself to protect files.
please check your card and look for a small switch, its usually at the side. click it up or down and try re inserting it to your cam. if this still isnt any help, it must be a setting on your cam.
hope this helps. :)
Feb 06, 2008 | Olympus Stylus 410 / ? 410 Digital Camera
Write protect turned off
If the write protection tab of the cassette is open(set to save), (STOP and Protection! will be displayed) Release the write protection tab to record
Dec 15, 2005 | Samsung SC-D353 Mini DV Digital Camcorder
Olympus PEN EPL1 Digital Camera Logo
13 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
