Question about Foxconn MB KT600 600A01-6LRS Motherboard
SATA Disk Problem
Hi ive plugged in the powere and sata cable for a new sata disk. However the system doesnt recognise it, nor does the bios. So im assuming / hoping this is down to a jumper needing changing?
Any help and/or a manual would be greatly appreciated.
  • Anonymous Dec 30, 2007
    Exact same problem. 600A01 m/b, has been working with a plain IDE drive. Added a SATA drive for additional storage. Not recognised by the BIOS. I've read the manual. I've fiddled around with all the relevant settings in the BIOS, and got nowhere.
  • Anonymous May 06, 2009
    I also have WD5000AAKS and I got second HDD almost dead
    I don't know why, but it looses hdd all the time (after couple months of work) and lots of bad blocks appear
Is it a SATA II drive?
If so, you need to jumper the drive to "downgrade" to SATA I before the Via controller will recognise it.
WD5000AAKS needs to jump 5+6. I don't know about other drives, but I'm sure you can find it.
I hope I've made your day, just as this info did to me when I found it!
Posted on Jan 12, 2008
In the bios you have the choice of the sata drive showing up as a raid driver or a ide, you have to change the drive to read as an ide then it will show up in your bios and you will be able to choose it as a primary drive.
Posted on May 27, 2009
Want to install a second sata hard drive, new drive not auto detecting, bios only identifies ide drives
HI popsrowe
Your problem is most likely the SATA data and power cables. for tips on the two cables. the system should detect the SATA hard disk automatically,
( you only need, setting the hard disk support as a second hard disk to the system in the bios setup )
regards
Jan 15, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Ive built my first pc and all went well until the message no hard drive detected comes on all parts are new so any help would be great in fixing this thanks dave
Verify that the hard disk is connected on both data and power cables and is receiving power (it hums at startup); also that the proper EIDE or SATA slot on the motherboard is used, and properly jumpered (e.g. a SATA 2 disk on a SATA 1 configured port is likely to malfunction).
Check that the BIOS is configured to autodetect the hard disk type, and is using the appropriate adapter (EIDE or SATA port), without RAID options or such.
In a pinch, try also ignoring the motherboard labels (e.g., plug the hard disk on the fourth SATA port instead of the first -- the mobo numbering is not always the "logical" one, even if it usually should be.
Jul 02, 2010 | Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
160gb SATA hardisk opareting system not installed
Check data and power cable. Verify in BIOS. Change SATA Port. Change SATA Cable.
Regards;
Hassan
Jul 14, 2009 | Computers & Internet
Problem with IDE & SATA Hard Disk
Have u tried changing ur jumper setting..which u can find near the power cable to the hard disk...and also U have to enable SATA hard disk in BIOS..
Dec 18, 2008 | MSI K8N Neo Platinum Motherboard
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Sp2004c sata hard drive is not recognised on system by bios or samsung hard disk manager all pluged in corectly to a new m/b, please help built a few pc`s now and not had this prob b4
  • Some SATA HDs have jumper for 1.5 G (SATA I) and 3 G (SATA II)mode. Try switching the jumper to 1.5 G or SATA mode (see motherboard manual).
  • Or you might need to upadte BIOS to support SATA drives.
Good Luck
Iqbal
May 11, 2008 | Computers & Internet
Flashing Toshiba satellite 1800-S204
Hi
You query did not give any clues abt the PC/Motherboard and its BIOS revision.
That said if the PC/BIOS will not "see" the HDD then its is unlikely a cause of a virus.
Some old motherboards can't recognise a HDD if its size is more than 137GB. Some older motherboard also require than you set the HDD jumper correctly (Master or Slave).
At this stage, i am assuming the HDD in question is PATA or IDE (Old Spec). If the HDD is SATA (New Spec), then you will need a SATA port to connect the HDD. Ensure not to use both "old" molex power connector and "newer" SATA power connector together.
If the HDD is SATAII but the SATA spec for your motherboard is SATAI (initial spec), some motherboards and SATAII drives require that you jumper the HDD to allow it to work at the lower SATA speed.
If none of the above points apply try upgrading your system BIOS of the latest version. Also review the mortarboard's manual for more info.
Regards
Mike
Mar 23, 2008 | Toshiba Satellite 1805-S204 Notebook
Computers & Internet Logo
399 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
