Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
How to change the flex cable on motorola z3 - Motorola Mobility MOTORIZR Z3 Cellular Phone
  • Official Brand Answer
  • 1,623 Answers
Repairs should only be done by trained repair person.
Mark
Motorola Support
Posted on Jan 27, 2015
3 Suggested Answers
  • 18 Answers
SOURCE: HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Posted on Dec 07, 2007
rajforu
  • 69 Answers
SOURCE: where to buy motorola mpx22o flex cable
you can purchse motorola mpx220 flex cable in delhi nehru place.
Posted on Jan 13, 2009
My MOTORAZR v9m's phone's screen went blue and whenever I open it up it stays blue. The outside screen is fine, its just the inside. I read that it had something to do with the flex cable. Is that right?...
Hello, Yes there may be a problem with the flex cable of the LCD, if you know how to open your phone try changing and replacing new flex cable. but be careul not to damage the flex cable, but if you are not familiar in opening the phone let the technician do that or you, Go to Motorola service center.
Sep 16, 2010 | Motorola Mobility Motorazr2 V9m Cell Phone
My phone is not charging up when I plug it into the charger
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 17, 2010 | Motorola Mobility C118 Cellular Phone
Where to buy motorola mpx22o flex cable
Jan 13, 2009 | Motorola Mobility MPx220
I need pc suite for free for my motorola z3 pls help than you
download P2K tools software which is compatible for all motorolaphones... it is having in built drivers also so install the driver bygiving the location where the p2k tools is located in that selectfolder "drv" ... this folder have all drivers when u connect ur cell topc through cable just install this... then u can upload or downloadanything from pc to cell & vice versa & you can flash the cellby using the flex option....
you flash the cell even when it is turned off from this software ..
it is available in this website
www.e398mod.com/content/view/165/28/
rate my solution
Sep 08, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
My motorola has driver problems
u should change ur data cable and u need to use proper data cable for rizrz3. GO phone settings----connection---usb Settings----memory card. lets try
Sep 05, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Z3 Blank/White Screen
replaced the flexcable on the phone.
USA - replaced either the flexcable and LCD
Mar 30, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
MOTOROLA Z3 PROBLEM
I've got the same problem!
Cracked my screen and when I tried to replace it with one I bought off eBay I got nothing but a white screen when I turned it on! Returned that screen and got another one from a different seller and still get the white screen. So I'm thinking its not the LCD screen, unless I just have bad luck. The keypad is also new, but now I'm gonna try to replace the ear piece flex cable set, because I can't figure out what else could be wrong with it. The phone powers on and operates as normal calls (incoming/outgoing with texts); I can even hear out of the ear piece.
So... Anybody have any ideas? anybody? breaker breaker...haha
Mar 27, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Camera connected
go to usb settings and change it to memory card
Dec 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Phone does not work properly
There is some pieces on the board inside your phone you broke off when you dropped it. It will need to be fixed by a technician. Hopefully you didnt brake the flex cable. Have them check the cable before doing anything else.
Aug 19, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
