Question about Fimco Industries Low Flow Handgun
Low flow handgun leaks around handgun, - Fimco Industries Low Flow Handgun
Water loss on a 2007 jeep wrangler no visible water spotted
No visible leaks--- BUT--- you see some coolant
around the intake !!!!?
Your going to have to realize that the water pump
can leak,the intake may leak & a head gasket or
radiator,hoses, etc can leak
We can not do the checking & guessing for you
Aug 12, 2014 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Po101 code
Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. Check for air leaks on or around any intake pipework using a good spraying of carb cleaner, if the engine surges then that's the leak. Check wiring to Maf and if the inside is dirty, again use carb cleaner liberally...NOTE: do not use Wd40... If the code comes back, it may be necessary to replaced the mass air flow sensor.
Jun 04, 2014 | 2000 BMW 3 Series
Leaking handgun karcher k785
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. !!
Feb 19, 2012 | Garden
How do i remove engine coolant cap on 2001 cadillac dhs
WAIT UNTIL YOUR ENGINE IS COLD,YOUR RADIATOR PRESSURE CAP IS LOCATED ON THE COOLANT OVER FLOW RESERVOIR, THATS WHERE YOU ADD COOLANT WHEN COOLANT LOW,YOU POUR COOLANT IN THE OVER FLOW RESERVOIR UNTIL COOLANT LEVEL REMAIN AT FULL COLD MARK DONT OVER FILL OVER FLOW RESERVOIR, WHEN COOLANT LEVEL STOP DROPPING WHEN ADDING COOLANT AND COOLANT LEVEL STAY AT COLD MARK ON THE RESERVOIR YOU RADIATOR HAS THE CORRECT COOLANT LEVEL IF COOLANT LEVEL KEEP DROPPING CHECK FOR COOLANT LEAKS AROUND RADIATOR AND THE TOP AND BOTTOM RADIATOR HOSES, LOOK FOR COOLANT LEAK AT WATER PUMP GASKET OR SEAL OR LEAK AT WATER PUMP WEEP HOLE IF YES REPLACE WATER PUMP.
Oct 23, 2011 | 2001 Cadillac DeVille
My 1995 subaru legacy lsi cuts out when I rev the engine around 1 rpm. Plus the check engine light is on. I took it to the dealership and they couldn't fix it, but they got a code from the check engine...
code p 0441 refers to evaporative emission (EVAP) system --incorrect flow detected ==== causes --- hose connection/s--- intake leak---EVAP canister purge valve replace the purge valve
May 21, 2017 | 1995 Subaru Legacy
A/C blowing hot air....any ideas it isn't the freon.
your temp. control valve is not closing off the flow of hot water , check for vaccum leak
Aug 28, 2009 | Acura TL Cars & Trucks
I was using the pressure washer and it stopped having high pressure and motor keeps doing a varoom--- pause----varoom----pause and does not stop doing this even with the wand off. Does anyone know what to...
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Apr 16, 2009 | Karcher PSI Electric Pressure Washer
Fimco Industries Low Flow Handgun Logo
27 people viewed this question
Top Fimco Industries Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Fimco Industries Garden Expert? Answer questions, earn points and help others
