Question about Sewing Machines
Not sure where to oil my sewing machine
I know it needs to be oiled especially for the bobbin winder but not sure where to do it.
    Sergeant:
  • Sewing Machines Expert
  • 455 Answers
Each machine has different lubrication requirements look to your user manual for lubrication points and how often to lubricate.
Cheers,
Kelly
Posted on Jun 16, 2014
RickE1
  • 202 Answers
SOURCE: Bobbin winder will not turn..
Without knowing what type of machine you have its hard to determine if the problem is mechanical or electronic. If the bobbinwinder has its own motor than its probably electronic and it could be a bad motor or circuitboard. Sounds like this could be it.
The minimum service charge could be about 50.00 but this won't include the more expensive part. You might look up Sidewinder bobbinwinders which is a small separate unit you can purchase in most fabric stores or online for about 20.00 and just wind bobbins separate from the machine.
Good luck.
Posted on Dec 20, 2008
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
caroldon
  • 17130 Answers
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
SOURCE: BOBBIN WINDER WON'T WIND
bobbin wont wind on sewing machine
Posted on Dec 08, 2010
SOURCE: Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
Posted on Dec 23, 2010
2001 Touch Tronic. Worked fine yesterday. Today, why can't I wind a bobbin?
If you haven't cleaned and oiled your machine recently, you might start there. Consult your owner's manual, use ONLY fresh, good quality sewing machine oil, and apply 1-2 drops of oil each spot specified in the manual.
If the machine bobbin winder is still not working, does it still sew? If so, you probably have two choices:
1) Take it in for service
2) Buy a standalone bobbin winder (~$30) from JoAnn's, Hancocks, or Amazon.com
If the machine does not sew, take it for service.
Dec 28, 2015 | Singer Sewing Machines
Toyota Industrial sewing machine bobbin winder not working
possibly seizing up from lack of lubrication or fluff jamming the workings
have it serviced by a service centre ( most any sewing service centre will be able to to the job unless it is still under warranty)
Jul 27, 2015 | Toyota Sewing Machines
Bobbin on Bernina 807 won't wind?
Please follow the logic checks and possible corrections:
1. Check the winder shaft for a sticking or a stuck condition. If stuck or sticking, add a drop or two of mineral spirits to the winder shaft and the winder support bushing. This will generally release the winder shaft.
If the winder shaft becomes free wheeling, clean off excess solvent and apply a drop of Bernina machine oil which is typically a class 68 machine oil. You can also use a common white mineral sewing machine oil.
Do not use WD-40 or 3 in 1 oil!
If WD-40 had been used prior to the winder seizure then you'll know why....Removing sticky WD-40 residues requires further measures.
2. If only the rubber wheel has hardened, you will need to replace the winder hub with a new hub and replaceable winder ring or the entire winder can be replaced. There are some very good after-market parts available online.
3. If the winder parts are good and you are describing a condition where the hand-wheel will not release so that the machine drives while trying to wind a bobbin, this would requite another question and detailed answer... SewTechnical Home
Jan 25, 2015 | Bernina Sewing Machines
Bobbin winder shaft wont spin
If you take it apart, you'll void the remaining warranty. The usual cause is not getting the door open completely and/or thread wrapped around the spindle.
You'll also want to take a look at: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=CS8150
Feb 11, 2014 | Brother CS-8150 Computerized Sewing...
HOW TO OIL THE BOBBIN WINDER ON A BROTHER RIVERA SEWING MACHINE
you might contact brother to see if you can oil the bobbin winder or if a sewing machine technican has to do it.
May 21, 2012 | Brother Sewing Machines
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
The bobbin winder on the top is not working. i can hear the motor going but it doesnt spin
Could be oil on the bobbin winder rubber inside. Make sure the bobbin is not rubbing anything.
Dec 12, 2010 | Singer 8280 Mechanical Sewing Machine
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
Bobbin winder stopped working
Either the winder rubber has worn down, or there may be some residue on the winder rubber, ot the winder may have seized through lack of oil which is quite common in that case it will need to be replaced
Mar 21, 2010 | Sewing Machines
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Sewing Machines Logo
69 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
