Question about General Electric Refrigerators
Lack of temp control relay click fan whirl
GE profile Artica PSC23NSTA side by side unit - The frigerator was not controlling temp well (generally displaying colder than set point- wild fluctuation) and occasionally relay on mother board clicks at frequency of about every 2 secs. Called GE they said unplug unit and allow board to reset -- tried but no help. There is a fan whirl sound from the upper right hand side of the fridge compartment and the lights dim when the relay clicks.
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
SOURCE: GE Fridge intermittent
I had the exact problem with my GSL25JFRFBS. It turned out to be a bad control board. The service technician that replaced the board said that the lights dimming on the on the ice/water dispenser is a direct indication of the control board being bad. This cost me $303.53 and my refridgerator is only a little over 2 years old. You can buy a new control board - WR55X10656 from GE online for a little over $157.00. From what I've found, this is an inherit issue with this model.
Posted on Nov 09, 2008
SOURCE: GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
Posted on Jul 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: HotPoint fridge clicks and the fan doesn't turn
14 vac indicates a bad motherboard.Clicking could possibly be a bad start relay on the compressor.
Relays are inexpensive. I would replace the relay and hope for the best. Next step would be the motherboard that GE has had trouble with from day one
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: I have a GE profile side by side model
Yes , the main control board is the problem . Also , make sure the coil roll behind the refrig , is clean . Sounds like the compressor relay on the board itself , is doing the clicking , trying to start a hot compressor , either caused by a compressor cooling fan not working , or the board . If the compressor cooling fan is not working , the board is still probably the problem . I have found , the board clicking , trying to start the fan . Replaced board , and no more problem .
Posted on Sep 25, 2009
Testimonial: "Thank you so much. "
We have a ge profile Artica, refrigerator side too cold. Keeps resetting temp to 27 degrees. Freezing everything.
Unplug for 20 seconds & plug back in... if keeps happening, replace the front panel controller.
Feb 21, 2015 | GE Refrigerators
I have a GE side by side Fridge that seems to get stuck in defrost mode and thaws the freezer out completely. When I tap the mother board with a screw driver it begins cooling again for a couple of days...
Yes I do believe your motherboard is very likely the problem. These motherboards are a common weak link for the GLS25 and all series of the Artica/Profile. Fact is any refrigerator that uses electronics to control mechnical and electrical functions has this weakness. Things that help cause this problem are failing compressor start components like start relay, start capacitor, defective condensor or evaporator fan motors and electrical surge.
WR55X10656 Board Assembly Main Control
Many times disconnecting power first and examine both sides of motherboard for signs of heat damage or burn marks. Sometimes you can see the bad sections of motherboard but not aloways. Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION
You will need Adobe Reader to open the service manual=> GE PSS26MSRSS Service Manual
This manual also covers your model. Acrobat Reader is available as a free download
If you have any questions or just need assistance in the repair I will be here to assist you, Thanks Sea Breeze
Sep 24, 2011 | GE GSL25JFXLB (250 cu ft) Side by Side...
The freezer temp same as refrigirator, 38 degrees. reset freezer temp to 0 but does not go down.
The GE Profile PSW26PSSBSS is a little tricky to examine sometimes. It sounds to me that you either have a defrost problem, fan problem or motherboard is failing causing all of the symptoms. To begin check inside the freezer and look over the rear wall to see if ice is building up. If yes then that will be an easy fix by replacing the defrost heater=> WR51X10055 Defrost Heater and Bracket Assembly
and defrost thermostat=> WR50X10054 Defrost Thermostat If no frost build up I would like you to pull away from wall, unplug and remove the lower cover and feel the top of compressor to see if the compressor is warm, cool or too hot to hold hand there. If too hot then I want you to make sure both fans are working inside and out and that they do not stop after a few minutes. If the fans are OK then it is possible the motherboard has a defective relay and will need to replace=> WR49X10152 Control Board You may need to examine both sides of the board for heat marks or signs that solder has been melting away from a relay. If it comes to this I will guide you through the repair and replacement. Click Here for=> GE Artica Technical Information And Click Here for=> GE Artica Service Manual Click here for the=> PSW26PSSBSS Back Side and motherboard is the item listed in photo as 801. And the Freezer Components Click Here=> PSW26PSSBSS Freezer Components and in that photo part 240 is the Defrost Thermostat and 230 is Defrost Heater. I will be here to show you what to do if you care for my assistance, Thanks Sea Breeze
May 09, 2011 | GE Profile PSW26P Stainless Steel Side by...
My ge artica model number pss25ngma the refer part freezes evertyhing. I have adjusted the temp but it goes back to 32 waht can I do?
check the evaporator fan; listen to see if it is running check the baffles between the freezer and, the refrigerator box for air flow. Check the control knob to see if it is turning the cold control shaft. If these are not the problem: replace the cold control
Mar 17, 2010 | GE Profile Arctica Stainless Steel Top...
GE profile TFHW22R side-by-side fridge compressor issue
Most times replacing the start relay part=> WR07X1001 start capacitor=> WR62X80 and overload=> WR8X97 will resolve the problem. Click here to downlod the Service Manual=>PROFILE ARTICA SERVICE MANUAL CLICK HERE and go to this page to use he Tech Sheet> GE Artica Profile Technical Information If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 26, 2010 | GE Refrigerators
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Ge Profile Freezer not working
Main pcb failure but just check the wireing at the bottom of the freezer door as it can affect the control system
Feb 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top General Electric Refrigerators Experts
Dan Webster
Dan Webster
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
