Question about Dishwashers
Kitchenaid DW,fill valve connection
When reconnecting a fill valve to b and b/w wires does bayonet connect marked w go to b/w wire and "b-4" to brown wire (b) leading to control panel...tell me if this is right ,it's what i did so far
THX this is working gr8t
Posted on Nov 02, 2007
  • 5 Answers
You are right on your connection. What you are attaching to is the coil of a 120VAC solinoid valve. On a 120 coil of a solinoid valve, it would not matter which way you attach to the coil.
Need 120 volt wiring diagram for model 113.299410 table saw with model 824370 motor
L1 L2 are the common or line,cord color doesn't mater, green is ground. also should be the ones with screws. try powering the motor for just a few second 2-3 at the most, if it snaps right to life you got it, if it starts slow or not at all, immediately shut it off and check the wiring again. pictures help us fixya guy help u better. there is thousands of different motors
Jay
Jun 03, 2017 | Pool & Spa
Magnetic Valve Assembly Part Number: BES820XL/198 leaks
Step 1: Unscrew back cover (4 torx screws and 2 phillips screws) and remove.
Step 2: Slide top warmer forward (may have to force with palm of your hand) disconnect ground wire.
Step 3: Remove valve assembly. While standing at rear of machine it is located in the rear upper left corner (on a 830xl), remove 2 phillips screws and disconnect wires taking note where they are connected. Remove split castanets from conecting tubes (push on one side then slide them off) making sure to also remove grommets.
Step 4: Instal new safty valve assembly reconect all disconected tubes with excisting grommets and reconnect all wires.
Step 5: Remount assembly with screws, reconnect wire to warmer top, slid backward into place and replace back cover with screws, connect to power, fill water tank and turn on.
Oct 16, 2012 | Breville Die Cast 800ESXL Espresso Machine
Need capacitor wiring diagram
No model number gotta shoot from the hip on this one:
The cap has 3 sections: Herm for compressor, F for fan, and C for common.
The common section of the cap gets a hot wire off the power cord, a wire from compressor marked C on compressor and a white common wire from the fan gets connected to C on that cap. These wires are almost always white in color on American OEM. The fan has a small brown wire that connects to F on tha cap. The compressor has a wire marked S on it make a note of that color wire and connect it to the section on the cap called HERM. Herm stands for hermedtically sealed compressor. So both your commons and a hot wire go to C. You need one small brown wire which goes to F from the fan. One wire marked S on the compressor goes to Herm for compressor starting. S stands for start winding.
Lets look at typical American fan motor wires: The fan has a black wire for high speed a blue wire for medium and a red wire for low. It has white wire for common, and a brown wire for capacitor. Connect your common fan wire to common and the brown wire to F.
With that cap properly connected basically all you would need to do to make it run is connect a fan speed, the compressor wire marked R for RUN, and and the other power wire.
Jul 20, 2011 | Fedders AEY08F2FCOM Wall/Window Air...
Wiring a generalaire 1042 humidifier to a goodman furnace,when there are no terminals marked hum
24 VAC HUM
The yellow wire connected to the I.D. Blower pressure switch
is powered anytime the pressure switch is closed and provides
24 VAC humidifier control. Remove the yellow wire and connect
the supplied brown jumper wire to the pressure switch
terminal. Reconnect the yellow wire to the "piggyback" terminal
on the brown jumper and then connect the 24 VAC line of the
humidifier to the stripped end of the brown wire. Using a wire
nut or a field-supplied quick connect terminal can make this
connection. The wiring must conform to all local and national
codes. Connect the COM side of the humidifier to the B/C
terminal on the furnace control board (or to the COM side of
the 24 VAC transformer). DO NOT CONNECT 115V HUMIDIFIER
TO THESE TERMINALS.
Feb 21, 2011 | Humidifiers
Please help.... kenmore 580.74124400 AC wiring color coded for the capacitor. wires fell off and all else works compressor is not turning on
Take a look at the capacitor. A terminal with just 2 connections is for the fan and has a small brown wire from the fan there and is usually marked with an F. The compressor portion of the cap has 3 terminals on it, usually marked as HERM for (hermetically seald compressor), a large brown wire goes there most of the time from the compressor. The other 3 wires all are white and go to the portion of the cap with 4 connections usually marked as C for common.
Jul 06, 2010 | Kenmore 75085 Air Conditioner
Kenmore dishwasher will not fill with water model no 630.1609406. It will run a full cycle but not fill. Water was temp shut off to replace kitchen sink and now dishwasher won't fill with water. No fill...
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Mar 29, 2010 | Dishwashers
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
5 ton carrier. we changed the condenser motor and marked where the wires connected. Old motor had yellow and brown to capacitor. New motor has an extra brown wire with white stripe... I connected it...
The best way to wire that motor is to connect a separate capacitor to it. The brown and brown w/white stripe go to the capacitor. The black and red wires go to the contactor.
Aug 06, 2009 | Heating & Cooling
Wiring in oven
If you are saying you are re installing this oven, then what did the 2 other wires go to before?
Feb 15, 2009 | KitchenAid Ovens
Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Jun 07, 2008 | KitchenAid KUDM24SE Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
