Question about LG Refrigerators
Lg Refrigerator alarm reset
LbC22520SW alarm keeps going off?
3 Suggested Answers
  • 137 Answers
SOURCE: I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
Posted on Nov 28, 2009
lgdinesh
  • 35 Answers
SOURCE: I have a labored groaning noise
may be compressor clamp is loose in back side check it
Posted on Jun 06, 2010
No power. How do I replace main board?
I was house sitting for my friend and her LG refrigerator all of a sudden died. Model: LBC22520SW.
I googled for this problem and found a guy who repaired his frig that had a similar problem and it turned out to be a burnt out fuse: (
http://thisdoesnotcompute.org/2013/04/21/fixing-a-completely-dead-lg-refrigerator/)
since the fuse was soldered onto the motherboard, I had to ask a techie friend to help (well, he's an over qualified techie -- actually a retired aeronautic engineer); but once we replaced the fuse, the refrigerator went back to work.
Cost of repair: $6.25 for the fuse, and $0.23 for the soldering wire (he used a high grade copper wire) vs. possible $300 for an "official" repair.
#braggingrights
Oct 28, 2015 | LG LBC22520SW Bottom-Freezer Refrigerator...
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 03, 2015 | Refrigerators
My refrigerator has a temperature alarm that keeps sounding every few minutes, how do I reset it the alarm?
Hi Friend, that's a great question!
The alarm of your Frigidaire refrigerator may typically be reset by either unplugging it or flipping the household circuit breaker. It is good to wait roughly ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly be experiencing a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend reaching out to a professional to proceed further. Best - Z
Aug 16, 2014 | Frigidaire Refrigerators
Lbc22520sw doesn't cool, compressor doesn't start, can't adjust temp
Compressor is probably running but has no freon I suspect that you have a leak
Nov 07, 2013 | LG LBC22520S (224 cu ft) Bottom Freezer...
LG Refrigerator LBC22520SW...After just installing a new control board 2 days ago, I now have an issue with my refrigerator beeping constantly, even when all the doors are completely closed. Also,...
Is anything at all working? Does it get cold? What was it doing before the Tech. came and put in the new board? Sorry for this very late reply. I am new to the site. I'll watch for you in case you still help.
Sep 20, 2013 | LG Refrigerators
2011 chevrolet tahoe security lockout... how do I reset it?
CAR ALARM ISSUES
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There are few help links with solutions, to troubleshoot these types of problems. I suggest going through these links.
Click the link below: ------
Volvo car alarm keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going OFF
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
2009 Toyota Camry: Hood Switch causing Alarm to go OFF?
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
Ford Pickup Alarm will not disengage?
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Mitsubishi Diamante: Factory Security Alarm will not go Off
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
Toyota Avalon Factory Alarm will go off?
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Chevrolet Tahoe Hood open warning on dash and alarm sounds?
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These details will help.
Thanks.
Nov 28, 2012 | 2001 Chevrolet Tahoe
I replaced a battery in my 2001 pontiac montana n the lights started blinking as if the alarm was going off.i hit the unlock n lock button n the blinking stopped. i have power,lights n radio but van wont...
Thanks.
Nov 28, 2012 | 2001 Pontiac Montana
1999 acura slx alarm
CAR ALARM ISSUES
Thanks.
Nov 28, 2012 | 1996 Acura SLX
Alarm goes off for no reason
It can be any of the car door not got properly locked or the door is locked but the switch is not sensing the door locked.Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.And last thing alarm connections needs to be inspected.Its getting short somewhere in between.
There are few helplinks with solutions,to troubleshoot these types of problems.I suggest going through these links.
Click the link below:------Volvo car alarm keeps going off for no reason http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
------------------ Alarm keeps going OFF http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
--------------2009 Toyota Camry: Hood Switch causing Alarm to go OFF? http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
----------------Ford Pickup Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
------------Mitsubishi Diamante: Factory Security Alarm will not go Off http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
------------Toyota Avalon Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
----------Chevrolet Tahoe Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
-----------These details will help.Thanks.
Nov 24, 2012 | 2005 Lexus ES330
Refrigerators Logo
46 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
