Question about Lionel 18952 Santa Fe Pa-1 Alco Diesel
Take apart lionel alco pa-1
Replace number board lights
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Sep 30, 2014 | Lionel Trains Holiday Express G Gauge...
User guide for RCA RTS736W 30-Inch Streaming Soundbar
No manual is available, the device is made by Alco Venturer you can contact them here
By Phone:
You may call Alco Customer Support and leave a message at
1-800-252-6123
or
1-905-477-7878
By E-Mail:
You may e-mail Alco Customer Support at these links
rca@1800customersupport.com
or
audiovox@1800customersupport.com
May 12, 2014 | RCA Rts736w 30" Wi-fi Streaming Soundbar
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
I need to order the power board of the freezer one door delfield/alco
Call Rick at Restaurant Parts and More. He can get you just about anything if you have model and serial numbers. Prices are reasonable and great service. Been doing business with him since '93 with out any problems. 1-888-814-1110.
Nov 20, 2009 | Delfield Freezer 6151XLSR Stainless steel
Why is a ''D'' battery needed for my Lionel Diesel engine?
This is just a guess but it may have powered headlights or other lights on the train at one time, some of then even had a smoke producing device on them.
Mar 19, 2009 | Lionel New Haven Freight Train Set
My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Nov 18, 2008 | Lionel Cw 80 Transformer
I have a durabrand portable dvd player i need a phone number to order a couple of parts for it thanks
Durabrand Technical Support, Parts and Accessories
http://1800customersupport.com/
Also the support division of these companies:
Audiovox
Durabrand
ILO
Kawasaki
Lextron
Magnavox
RCA
Trutech
V7
Venturer
The actual manufacturer:
Alco Electronics
Hong Kong
Company : Alco International Ltd.
Address : 11/F, Zung Fu Industrial Building, 1067 King's Road, Quarry Bay, Hong Kong.
Telephone : (852) 2880 0698
Fax : (852) 2880 0858
E-mail : marketing@alco.com.hk
Website : http://www.alco.com.hk
EUROPE
Company : Venturer Electronics Europe Ltd.
Address : Unit D, Bourne Park, Cores End Road, Bourne End, Bucks SL8 5LS, United Kingdom.
Telephone : (44 1628) 527 757
Fax : (44 1628) 527 794
http://www.alco.com.hk/main/
Aug 19, 2008 | Durabrand Portable DVD
TruTech 32" Flat Panel LCD TV
noavatar_s.pngBy nonexpert_s.gif Greasmonk
Rank: Apprentice
Rating: 0%, 0 votes
Heres what mine did:no picture no sound, when i hit the remote theindicator light went out....six months old, cant findany info on it, cant get a hold of anyone at Trutech.
Soi took it apart, on the board that the power cord is attached to, ifound six blown capacitors. There is also a big ass one in the middleof that board which looked ok but blew out the bottom.I replaced them,and im watching it as i type.
Its fairly easy but if your not comfortable soldering on a cheap circuit board, take it to someone.
I hope it helps, i think this repair will fix the other Trutech models with the same problems.
Eric
ed44309@hotmail.com
Nov 18, 2007 | TruTech PLV16320 Television
Lionel 18952 Santa Fe Pa-1 Alco Diesel Logo
41 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
