Question about Radio Communications
Pairing instructions ce aja1 - Radio Communications
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
CE022BM Cascade Breadmaker CE-022BM
Are there any product codes on your belts? The will look similar to this if you have them: 60S3M503 or 80S3M485 etc. etc. email those codes to me at daryl441@msn.com
Dec 30, 2013 | Cook's Essentials CE022BM Cascade...
My Bluetooth device (CE 0979) has just stopped working. Green light flashes non-stop. How do I get it going again?
Turn off the Bluetooth device and turn off your phone. Turn your phone back On. In your phone go to Bluetooth and remove permission for the device. Re-start your phone. Turn your phone back on and pair your device. The passcode is probably 0000 (four zeros). Once paired it should work properly.
(Note: Make sure your Bluetooth device is fully charged before attempting to pair it.)
Feb 05, 2011 | Nokia E51 Cellular Phone
Lost Pairing instructions for Jabra Earpiece CE
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
May 30, 2010 | Jabra BT2020 Bluetooth Cell Phone Headset...
Ce-100
Go to www.futura-support.com , select "Futura machine" in the left hand menu, click on Instruction manuals, select your machine and download. Presto!
Dec 10, 2008 | Singer CE-100 Futura Computerized Sewing...
I cant pair my motoh700 whit my samsung sgh-e496
ce n'etait pas un casque wireless c'etait de preference un casque bluetooph mais tout es resolu a present je vous remercie.
j'ai rechager mon casque juste pendend quelque minute, pour le mettre en mode pairing j'ai juste apuiyer sur le bouton jusqua ce qu'il devient mauve apres j'ai vite ouvrir le micro qui etait plier pour la lumier mauve soit solide puis je l'ai chercher avec mon telophone apres l'avoir trouver je l'ai connecter et puis tout es bon a present merci
Sep 11, 2008 | Motorola Mobility H700 Wireless Headset
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
