Question about Holley Vehicle Parts & Accessories
Holley 670cfm tbi troubleshooting - Holley Vehicle Parts & Accessories
  • 660 Answers
Need more info
Posted on Nov 29, 2014
Holley 470 flooding when not started
Needs a rebuild. Diaphragm is sticking in it. Holley carbs are notorious for that. I highly recommend running 93 octane or higher when using a Holley!!
Feb 20, 2015 | Cars & Trucks
How do i install a manual choke on a holley 600 carbie
Go see your local Holley dealer, a manual choke conversion kit should be available.
Oct 18, 2014 | Holley 0-1850c 600 CFM Four-Barrel Vacuum...
Need a carburetor vacuum hose diagram 1983 dodge rampage
Vacuum diagram? - Turbo Dodge
www.turbododge.com > ... > Carburetted and TBI Injected . you should be able to find every thing you want to know here
Feb 04, 2012 | 1983 Dodge Pickup
I have a high idle problem , with a 91gmc 1500 no codes but my scanner has a troubleshooter guide it says the seal gasket for the TBI is leaking vac I tested the TBI and it is working properly so I...
With the TBI, the AIC solenoid can get stuck and cause problems. It's on the passenger side of the TBI assembly and should have a four wire harness attached.
May 07, 2011 | 1991 GMC Sierra
How to adjust floats on a 1250 holley carburetor
There are complete instructions from Holley;
Click here and print the PDF file if needed.
http://www.holley.com/data/Products/Technical/199R9786-2.pdf
Aug 15, 2010 | Holley 36378 Carburetor Tuning...
Replaced TBI with Carburator, 4L80E wont shift
all u need to do is get a holley electric choke carb model i think is 4150 or 4160 and get the tps sensor adapter for it it is around $110 and the carb is around $290 ur trans shifts off of the tps. all the other sensors are useless. i had that same problem with my 94 silverado.
Nov 10, 2009 | 1991 GMC Suburban
New rebilt carter yfa installed, but idle at 3k all adjustment screws backed out, ? the 2.5 L 4 cylinder came from P O with a jury rigged rochester carb of 77 ford vintage, hard to start so I got the...
The 2.5 L engine is the Pontiac Iron Duke sourced from GM since it was still AMC. They came with Rochester carbs, while Ford used Holley 2 brls on their 4 cyl engines and Chrysler used Carter carbs. You might have the wrong carb and the throttle plates are sticking on the intake manifold. You can try using a carb adapter/spacer. If you drive off road I would suggest buying a TBI throttle body injection system from a junkyard, and pick up a electirc fuel pump. Either new from a speed shop or used from a newer Jeep with a 2.5 L TBI engine, you'll need the computer, harness, relay, sending unit and lines as well. But you can pick up everything at a pick your part yard for cheap (some yards have all you can carry in your hands for $50 days).
Jul 27, 2009 | 1985 Jeep Cherokee
Vehicle Parts & Accessories Logo
Top Holley Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Holley Vehicle Part and Accessory Expert? Answer questions, earn points and help others
