Question about Ryobi Garden
I have been given a Garden Gear hedge trimmer with a 18V ET-D1801 but it has no chrger with it. I sit poissible to get a compatable charger?
boscia
  • 163 Answers
SOURCE: Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
Posted on Nov 28, 2008
trippssmengi
  • 76 Answers
SOURCE: need the main handle hsg assembly -part 300183 & battery pak 300210
Your best bet and cheapest would be to go thru sears at www.searspartsdirect.com
Posted on Mar 02, 2009
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
  • 7 Answers
SOURCE: can i charge a 14v battery using a 18v charger (both are ryobi)
Absolutely not. The risk of damage to the battery is only a minor concern compared to the fire hazard you would be creating.
Posted on Jun 11, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
Are replacement batteries available for grass trimmer NOE-2ET-230 and hedge trimmer MOE-ET-410 if so where can I purchase
readily available from the manufacturer spares or manufacturer service agents
May 29, 2017 | Garden
How long should it take to Charging Qualcast 18v pole hedge trimmer battery
either the battery is dying try another battery if another one does that its a bad charger
Aug 24, 2014 | Garden
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
I need a new power pact.
If you are looking for the battery, here is the information Power GlideĀ® 18v Cordless Trimmer Battery (60101271)http://www.acehardware.com/product/index.jsp?productId=2463050
Power GlideĀ® 18v Battery Charger (60101272)
http://www.acehardware.com/product/index.jsp?productId=3497457&cp=2568443.2568444.2598675.1327540.1260415
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Ace Hardware Power Glide Cordless Hedge...
How long should I charge a new 18V battery for a Draper cordless hedge trimmer for? Just bought. First time it's been charged.
24 hours,then run the trimmer till the batteries are dead.That helps them to hold their charge longer the next time.
May 20, 2011 | Garden
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
Garden Logo
116 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
