SOURCE: problem printing with IBM 4610 TF6
Download and use this driver instead, EPSON TM-88II Printer Driver, 4.00.
Good luck.
SOURCE: Could some1 send me the driver for 4610 suremark
Here is the current driver for the suremark 4610;
FTP
SOURCE: I have a IMB 4610-TF6 and it's making weird
ummm did make sure your .exe was in english first?
Testimonial: "Hi Solution #1, Thanks for replying. When I install the driver, there is no option to select English. I am using a RSS Port and select COM2 as the por"
SOURCE: driver IBM printer 4610 suremark for windows xp
You can find the driver here: http://www-01.ibm.com/support/docview.wss?rs=219&uid=pos1R4000123
SOURCE: Printing only one side
-Open the top lip of the printer
-Remove/pop off the black cover inside with the 2 stickers on the top
-Using 2 fingers push down on the brownish connect, where several white wires feed into, do this on both each sides
-Test print job
