Question about Dell Inspiron 1300 Notebook
When i turn on the laptop a light comes on for about 5 seconds then nothing just black
  • 34 Answers
Try removing the battery and reinserting it after cleaning the contact points. Also check whether your adapter is ok. It might be your adapter is not working and battery might have run out
Posted on Jun 19, 2009
HP 2000-410US when turned on the power light button blinks 1 time every 5 seconds, nothing elas
1. Disconnect anything that is connected to your laptop. Usb Flash discs, External HDDs, Wireless Devices using dongles etc.
2. Make sure that your device does not receive any power i.e. Disconnect your ac cable, and remove battery from your laptop.
3. Hold down the power button for 5 seconds. This would drain remaining power from your laptop. But as the power cable and the battery are disconnected, you should not expect anything to happen.
4. Identify where your RAM is located under your laptop. Unscrew the cover off, then remove the RAM from your laptop. Replace the cover temporarily.
5. Flip over your laptop. Connect your power cable to the laptop, NOT THE BATTERY NEH! Then press the power button. Sometimes your laptop will make long beeps to let you know the RAM is not inserted in your laptop. But nothing will happen on your monitor because it needs RAM to show you something.
6. After those beeps, remove the power cable. Press the Power Button to drain remaining power on your laptop. Flip the Laptop and replace the RAM you have removed earlier.
7. Insert your power cable and try restarting your laptop and see what happens. I am sure by now you should have some response on your laptop monitor.
NB: While performing the above mentioned, remember PC or Laptop parts are delicate. Even static electricity can damage them. Thus before handling your laptop components, make sure you touch the wall or any large metal subject from time to time to discharge the static. Wear 100% cotton cloths as you are working on it. Bare feet even better to discharge the static
Jun 14, 2014 | Gateway MX8711 Notebook
I switch the power on power light comes on fan starts as if to boot then nothing, no screen and no keyboard lights
Does BIOS messages appear, or is the screen absolutely black?
If you see BIOS messages and then black screen, you should go to BIOS and choose your boot devices correctly. If there is no screen do the following tip:
1) Turn off the laptop.
2) remove the battery.
3) click and hold power button for about 30 seconds to discharge the circuit from motherboard.
4) then install the battery again
5) and click power button.
See what happens. In many cases it helps.
If there is still black screen, you should check your laptops RAM. In many cases removing and then installing back the RAM helps.
Oct 19, 2013 | HEWLETT-PACKARD HP 630/P6200 Notebook
Compaq presario cq71 power indicator comes on for about 5 seconds then turns off without battery
cq71 check tips:
please clean memory stick pins and slots first if not ok, check next
1) plug in adapter to check jack led lights on or not, if no lights on no switch on.
2) if the jack lights on, then to switch on laptop, will be showing the more lights on, you are hearing cpu fan running. if nothing appear or every thing running with dark screen, or hard to switch it off go next
3) pull out the wireless card then switch on again, see what happened, if ok change a new card, if not ok, it is motherboard hardware issue
Dec 29, 2012 | Compaq Presario CQ60-220US PC Laptop
Dv9815nr Entertainm​ent PC turns on for 5 seconds then turns off
I have to agree with them if you tested everything else. It could most likely be a mother board issue. It would benefit you to purchase another computer and not try to replace the mother board if its NOT under warranty. That MB will be expensive.
May 27, 2010 | HP DV9815NR Pavilion Laptop
Tv comes alive for 5 seconds then nothing
you may have a bad backlight have a qualified technician quote a repair and weigh price vs new technology replacement.
May 21, 2010 | Televison & Video
My dell Inspiron 1420 will not power on. when the power button is pushed the power light comes on for about 3-5 seconds followed by the battery light for about 1 second and thats it. nothing else comes on...
a dell inspiron 1420 is a laptop you have put it under printers
im assuming your talking about a laptop
try charging your laptop or turning it on with the charger still attched to the laptop
if laptop does not turn on with the charger attached then either that the battery is dead and you need a new one or your laptop itself is gone
Dec 30, 2009 | Office Equipment & Supplies
My vaio pcg-k15 does not boot up
Try to get into Bios by hitting F2 or Del key immediately after turning on your laptop. If it enters Bios, then there is a problem with your OS. Try reinstalling the OS if so.
thanks...
Dec 20, 2009 | HP Compaq Presario R4000 Notebook
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Went black and won't turn back on.
if the ac adapter is good
thats the first thing you shoudl be sure of
next the jack in back of the laptop may need replacement
they cost 5 to 10 dollars on ebay, if you can move the pin in the jack or is loose , then its the dc jack
Apr 21, 2009 | Computers & Internet
Laptop wont turn on philips freevents x51
The most likely problem is that your Hard Drive has Died.
If you can readily access another Laptop HDD, try it and see.
Other than that, I'd say the Motherboard has decieded to give up the Ghost.
Just Remember, A Laptops life expectancy is 3 years, after that you are treading on thin ice keeping Important Documents on it.
Nov 27, 2008 | Computers & Internet
Dell Inspiron 1300 Notebook Logo
35 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
