Question about Radio Communications
Have a cobra 29 classic the power wires pulled out of the board where do u soder them back into
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Hold the radio as if you were looking at the knobs.Now look to the inside of it and look at the top RH corner where the transformers are. Yuo should see in that are some I.D. markings.Look for W3 and W5thats where your wires go.use a volt meter to find common ground and that is your black wire.good luck
Posted on Sep 15, 2014
2 Suggested Answers
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
Posted on Apr 24, 2009
Were do i connect the blue wire from the rfx 150 into the cobra 29 lx
didn't you get direction with it for installing it in a 29 lx?
Nov 08, 2013 | Cobra 29-LTD 29 LTD Classic CB Radio
My cobra 29 classic wont turn on
polarity protection diode near power input burnt.
Apr 14, 2013 | Cobra 29 LTD CB Radio
Radio cuts out occassionally...no transmit,no receive.if i tap bottom of it,it comes back for awhile.it's a cobra 29 ltd classic,has bigger finals and connex board installed.
Hi, my name is John. Welcome to FixYa. Take the cover off circuit board side, and with the eraser end of a pencil, touch around on the board trying to locate cold solder joints, have to look real closely and re-solder them....Thanks for choosing FixYa...John
Nov 21, 2010 | Cobra 29 LTD CB Radio
Installing echo board
red wire 12 volt all time conected to power supply and orenge wire 12volt when is on and 0 volt when is off ,this wired are in on off switch.
Mar 25, 2009 | Cobra 29 LTD CB Radio
POWER CORD
check your ground wire and make sure it is getting a good connection because if not you will keep blowing fuses after a while
Jan 06, 2009 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 07, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
22 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
