Lavado de tambor - Washing Machines
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: no quiere secar
Si bombea el agua hacia fuera entonces usted necesita un nuevo uso del acoplador esta guía
Posted on Feb 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: no realiza el sclo de lavado
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Mi lavadora funciona, pero cuando llega al ciclo de torcer hace un ruido como que golpea y parece que camina lavadora whirlpool w10250884
Hola '
Suena como los cojinetes en la parte trasera del tambor se han derrumbado.
Si el tambor est? suelto y ruidoso cuando se gira a mano significa que los rodamientos han desgastado.
Este es un gran trabajo y probablemente ser?a m?s barato comprar una nueva m?quina.
Buena suerte.
Nomess
Feb 24, 2015 | Whirlpool Washing Machines
Ruido en el freno trasero derecho de un toyota 2003
Es util saber si tienes frenos de tambor o de disco. Si es de tambor tienes que revisar el desgaste de las zapatas y tambien ver que este bien armado. Puede haber polvo o algun material que no debe estar alli. Si son discos puedes ver el desgaste a travez del caliper. Espero que esto sirva.
Apr 16, 2014 | 2003 Toyota Corolla
Ha algum reset do tambor de imagem da hp laser color 100 m175a
Alem de instalar uma nova bateria, eu nao tenho conhecimento de uma reposicao para ele. Talvez haja uma outra pessoa em fixya.com quem sabe de um procedimento de reset?
Jan 08, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
Por que la lavadora no exprime y se queda quieta
Tengo una lavadora nave de 39 libras y cuando empieza el ciclo de lavado se queda quieta y el bombillo empieza a parpadear que debo hacer?
Mar 08, 2011 | GE Washing Machines
Mi secadora Whirlpool care II se oye el motor funcionando pero no gira el tambor de adentro
posiblemente sea que la correa del tambor se rompio. tambien pudiera ser que la usaron sin el filtro(lint screen) y se trago una media u otra pieza de ropa y esta atrapada en el abanico del motor o se le rompio la parte tensora de la correa. de todas formas tiene que desarmala para ver que tiene. suerte.
Feb 06, 2011 | Whirlpool Dryers
Aparece la palabtra sud Que En El manual es Exceso
El "SUDS" error puede ser causado por demasiado detergente, detergente inadecuado, bomba de desagüe / drenaje problema de línea, o mal funcionamiento del interruptor de presión.
1. Si no está usando detergente HE, usted necesita estar. Estas arandelas están diseñados para usar detergente SE que se formula para las tinas de lavado que el uso de 5 a 7 galones de agua. Si utiliza un detergente común, que son, en el afecto, colocando una mayor concentración de detergente en la lavadora que normalmente se formulan para las tinas de lavado que tienen una capacidad de 35 galones. El fabricante debe contar con un descargo de responsabilidad en el propietario explicar este manual. En la mayoría de los casos esto también se anulará la garantía. NOTA: El uso prolongado del detergente equivocado puede dañar los componentes de la bomba de drenaje y / o lavado de sellos bañera.
Si está usando el detergente correcto, vuelva a revisar la etiqueta para asegurarse de que no es el doble (2X) o triple (3X) concentrado. Usted aún podría ser puesta demasiado jabón en su lavado.
Para deshacerse de demasiado detergente, coloque la lavadora en un ciclo RINSE & SPIN, a continuación, ejecute a través de un ciclo normal de lavado sin detergente agregó. Es posible que tenga que repetir estos pasos dependiendo de la cantidad de detergente utilizado.
2. Si usted no tiene un problema de detergente, vuelva a comprobar la fuga de la bomba y las líneas de drenaje para asegurar que no se obstruyan de ninguna manera. Retire el panel de pie inferior debajo de la puerta y retire la tapa de desenrosque en el desagüe de la bomba y verifique el colador. Obstrucciones en la bomba de desagüe y / o las líneas de desagüe se puede atribuir a la atmósfera quedar atrapado en el desagüe de la bomba y hacer que el código de error.
3. Revise todas las conexiones eléctricas a la bomba de desagüe y Unidad de Control Central (UCC). Usted tendrá que quitar la tapa superior de la lavadora para acceder a la UCO. Esto se logra mediante la eliminación de los tres tornillos en la parte posterior de la lavadora que sujetan el panel superior en su lugar. Con los tornillos quitados, deslice el panel trasero, y luego se apaga. La CCU se encuentra directamente detrás de la tina de lavado en el centro de la lavadora. El conector de la bomba de drenaje será el sexto conector (vistos desde el frente de izquierda a derecha) en el centro de la UCO.
4. Revise el interruptor de presión para asegurarse de que es bueno. El interruptor de presión se encuentra a la derecha de la CCU según se mira desde el frente. Es un pequeño dispositivo de forma cilíndrica con un conector y una manguera de aire conectada. El interruptor se puede controlar en varios niveles de agua quitando el tapón de la resistencia y tomar las lecturas a los pines del conector. Las lecturas son como sigue:
(Los pines se numeran de I a L frente a la de la parte trasera)
Los pines 1 al 2 (SUDS Detect) - 0 ohmios
Los pines 3 a 4 (cont.) - 0 ohmios
Los pins 4 a 5 (L1) - 0 ohmios
Pins 4 al 6 (Empty) - 0 ohmios
Espero que esta información tiene carácter informativo y útil.
Jun 18, 2010 | Kenmore Elite 45986 Front Load Washer
Tiene bibracion o los esprines estan fuera de lugar o el balance del tanque esta mal puesto no se con las imagenes del sistema creo poder
Podria ser que una pieza parecida a una "y" que sostiene el tambor interno en la parte posterior del mismo se haya corroido por contacto de bimetales ya que la "y" normalmente es en aluminio y el tambor en acero inoxidable. La unica forma de accesar esta pieza es desarmando practicamente toda la lavadora para accesar el tanque y luego separar la cubierta plastica para accesar el tambor. No necesariamente tiene que ser esto, esperemos que no... Tambien podria ser un soporte interno roto. De cualquier forma, remueve la cubierta inferior (si la tiene) y echale un vistazo a los soportes.
Apr 21, 2009 | Kenmore Washing Machines
No quiere secar
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
No puedo imprimir
apaga la impresora y retira la unidad de tambor que es donde esta el deposito de desperdicio y colocala de nuevo
Aug 27, 2008 | Kyocera FS-4000DN Laser Printer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
