Question about Panasonic TC-P50X5
Tv wont turn on
Lost power now tv won't turn back on
WON TURN ON
For the first step, try using the button on the TV itself.
Secondly, check if the power cord is snug, and not burnt. Sometimes after a blackout, there would be a power surge, and that might burn your plug.
If both doesn't work, the fuse in your TV may be blown, or the Power Supply may also be burnt too. If this happens, you're going to have to hire an expert to help replace the broken parts.
Note that in some TV models, the fuse can be replaced by users. If this is your case, try checking the fuse to see if it's blown or not.
Feb 02, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Jan 23, 2013 | Televison & Video
Phillips
The main power regulator board is faulty. It should be replaced.
Aug 13, 2012 | Televison & Video
Died and wont crank
If it died and won't crank, sounds like you lost power to something.
Does the warning lights come on when you turn the key on ?
Got headlights ?
A mechanic would check for voltage at the starter and work back from there.
Jul 25, 2012 | 1996 Chevrolet C3500
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
Why wont my tv turn on
Hello
Do any indicator LED at it front panel lights up? If lights up, and the TV won't turn ON, the fault is with its internal circuit board. If not, the fault is with its power regulator board.
Feb 07, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
Lost the remote to the tv now it wont turn on manually
the remote has nothing to do with the tv not turning on or off you should be able to push the power button on front of the tv and turn it on that way.if its not staying on then theres something more wrong than just a lost remote
Jan 21, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Panasonic TC-P50X5 Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
