Question about Pool & Spa
Jandy lxi pool heater manifold recall? - Pool & Spa
2 Suggested Answers
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
Y Jandy LXi pool heater will not start, it keeps reading no flow although all valves are properly set.
check preesure switch to see if voltage both sides if not clean out copper tube probably calcified
Mar 15, 2015 | Jandy Lxi Natural Gas Pool Heaters
The heater won't light up on my Jandy LXi400n Lxi heater
make sure red light is on for calling for heat if so make sure 24 volts ac on both sides of pressure switch if ok make sure gas is on
Jul 13, 2012 | Jandy LXI400N Lxi Pool & Spa Heater -...
Jandy lxi heater low pressure warning
check filters if ok check pressure switch and tube going to it
May 17, 2012 | Jandy LXI 400 NATURAL GAS POOL HEATER -
New jandy LxI 400 natural gas pool heater makes a howlering sound which starts after it runs for about five minutes. The noise starts soft and continues to get louder. The noise is loud. Once I shut the...
Your bypass valve is bad. Probably because you did not pay attention to your water chemistry. It is located where the pipes enter the heater. You remove it from the side of the manifold that is outside the heater. It is not a difficult job. Just make sure your pump does not come on while the heater manifold is open!
Apr 16, 2011 | Jandy LXI 400 NATURAL GAS POOL HEATER -
How do I increase the water flow on a Jandy LXi pool heater?
You can not increase the water flow through a heater by adjusting the heater. You either need to get a larger pump motor, fix a pump issue, or....
If the heater was installed correctly with a bypass, closing the bypass will force more water through the heater. If a bypass was not installed, a larger motor is needed to increase flow (unless you used to get enough flow and now you dont. I this case, fix the pump or backwash the filter)
Feb 15, 2011 | Jandy LXI 300 PROPANE POOL HEATER -
Won't ignite
make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Jun 02, 2009 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Pool & Spa Logo
43 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
