Question about Belkin Surf N300 Wireless N Router
Hit reset on password - Belkin Surf N300 Wireless N Router
User name & password, please?!
Please click on "FORGOT PASSWORD".
Jun 16, 2017 | Computers & Internet
Tip
How to bypass Windows XP login passwords from scratch.
1.Download isoburner and rwps.iso
2. Extract isoburner.zip to your desktop.
3. Run: "IsoBurner.exe"
4. Select: "Create bootable USB disk"
5. For "Source ISO image file", select: "rwps.iso" (which is the password reset files) Hit: Next
**With WinRAR installed on your computer, it will make that file appear as an archive, but the properties show it is a .iso)
6. Plug in the USB device you will dedicate as a Password Reset, and select it from the drop-down box. Then hit: Create
*Once you hit: Create, it will dedicate your flash drive as a password reset USB drive. You will have to completely format the USB if you decide to remove the files in the future (it takes a couple minutes)
7. After created and your USB is flashed, plug into your computer that you are locked out of.
8. Boot up and you will have to hit ESC / F2 / F4 (depending on type of computer) to open your computers boot options.
9. Select your USB device and hit: Enter and it will run the password reset.
10. Leave Step 1 and 2 alone, it will auto direct to the SAM and System files, which store all computer passwords and accounts.
11. In Step 3: Select which account you will like to reset the password for.
12. In Step 4: You can change your password to a different one, or leave it blank for no password, then hit Reset. When prompted the Messagebox, click OK, and then save the file wherever you'd like. (Suggested to leave where it directs to with the other password files)
13. Hit Exit, and restart your computer. Boot regularly, and there you go!
on Feb 09, 2014 | Microsoft Windows XP Professional With...
I forgot my username and password. how do I reset them
Go to where you usually sign in. Hit forgot password, then create a new password. Reset password. Hit forgot username and reset user name.
May 14, 2017 | Computers & Internet
I brought a bizhub 420, how do i reset password
I had an older Minolta a couple of years ago. I'll try adapting what worked for it to this machine. Hopefully this will work.
Press the "utility" button. Then hit "admin settings". Enter a password of 12345678. Then hit "user authentication" and put in "off". Hit panel reset from the main menu.
Again, I'm not entirely sure this will work for the 420 but its worth a shot. Good luck!
Apr 26, 2012 | Office Equipment & Supplies
How do I reset my password?
if you go to voicemail then it will say hit "u" for user options, then hit "p" or "7" to change passcode.
i just did that(:
Nov 16, 2011 | Mitel 5220 IP Phone
My net book is locked and i forgot my password
Hello!
Solution 1: if you have windows 7 installed and luckily you have made the Password reset disk then it can reset your password..
Solution 2: if you have windows xp/vista then try to hit Ctrl + Alt + Del and then enter USER ID = administrator and PASSWORD = administrator. (this will only work if you have Standard user a/c and the admin A/c haven't been configured. )
Solution 3: If nothing above mentioned can be resorted then to last resort use the third party Linux Live CDs to reset passwords.
http://sourceforge.net/projects/systemrescuecd/files/sysresccd-x86/2.2.0/systemrescuecd-x86-2.2.0.iso/download
boot from the cd and follow the instruction ,
To brief it out : step 1 : ntfs-3g /dev/sda1 /mnt/windows -o force
step 2 : cd /mnt/windows/Windows/System32/config
step 3 : chntpw -l SAM
step 4 : chntpw -u username SAM (replace word username with your login userID)
step 3 : press 2 hit enter and then enter new password then again hit enter and press Y to save and then hit enter.
Note : The above steps may change according to the PATH..
Done.. your new password has been set.
Jun 17, 2011 | Lenovo IdeaPad S10e Netbook
How to reset password on playstation 2
Hi Jessica
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
  • Power on the PS2
  • Press the Reset button
  • Inset an R-rated and wait until the board comes up telling you that Parental Control is on
  • Hit the Select button
  • At the enter password prompt, hit the Select button
  • At the Delete password prompt, enter in your password
  • Hit the X button
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
  • Unplug the PS2
  • Wait approximately 72 hours
Hope this helps :)
Mar 20, 2011 | Video Game Consoles & Games
How do you reset the password for voice mail features?
If it's for someone else's extension, you go into Admin (Feature 983) and hit Mailbox, Chng, type in the mailbox number and hit reset. This will reset it to 0000. If you've forgotten the admin password, I found a great online cheat sheet on how to change it, let me know if you need it.
Jan 20, 2011 | NorStar M7310 Corded Phone
I have a Toshiba Tecra 8100 notebook someone gave to me, it asks for a password, and I don't have it. How do I reset it?
You may not need to reset it. Have you tried hitting enter? I have had a number of Toshiba's and never wanted a password so I just got around it by hitting the enter key with no password..
Mar 19, 2010 | Toshiba Tecra 8100 Notebook
Reset password on Zillionz ATM Machine
after you hit the reset button hit 1234 enter that should be right..
Jan 30, 2010 | Summit Appliances Division Youniverse...
Belkin Surf N300 Wireless N Router Logo
27 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
