Question about Lowrance LCX-25c GPS Receiver
Lowrance hard reset - Lowrance LCX-25c GPS Receiver
How do you manually reset a lowrance eliite 5
You can try holding in the zoom in/out buttons (+/-) as you push and release the power button.
Hold the zoom keys until you hear a beep.
If your hard restart is successful. You should see the GPS screen with prompts for language etc.
if you cannot get the system to cooperate and all you see is the "Lowrance" screen, then you are experiencing a Castro pic system failure and the unit needs to go back to Lowrance.
Jun 21, 2015 | Lowrance Elite 5 Color SonarGPS Combo
Comes on white screen then off just for a second
If possible, try to restore the device to the newest firmware on it using your computer using this firmware:
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-18C/Downloads/LCX-18C-Software-Update/
OR
Do a soft reset. This may resolve your issues and will also keep your data on the device.
Do a soft reset by:
1. Having the device already off
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
If neither of those work, try a hard reset. This will however delete all stored data off your device.
To do a hard reset:
1. Have device off
2. Press and hold the ZIN&ZOUT Keys at the same time
If none of these work, contact Lowrance at 1-800-628-4487
Mar 05, 2011 | Lowrance LC X-18c GPS Receiver
Lowrance globalmap 2400 on/off button stuck, unit tries to turn on then screen is blank, tried wiggling back and forth no luck, should i send it in for repair and where to...live in carroll county, md....
You can try a hard reset:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you get the "WARNING, DO NOT RELY..." message.
If that doesn't work, try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it still doesn't work, and you can't get through to Lowrance by phone, try emailing them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
It probably won't be worth repairing the unit. You will be better off putting that money into a current unit which will be much better than the 2400 and probably less expensive than the 2400 was when it was new.
Mar 23, 2009 | Lowrance Globalmap 2400 GPS Receiver
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
Need to know how to do a hard reset on the unit-lowrance533
try this ,
1.) turn off unit
2.) press and hold pages key
3.) press and hold power key
4.) release both buttons when the USA map appears
was for the 5300 searies , hope it helps ya.
Dec 25, 2008 | Lowrance 5300C GPS Receiver
Lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Oct 18, 2008 | Lowrance LMS-330C GPS Receiver
We have a X23 Lowrance. It was working OK then it just went to flashing 0.5m with bits of blue colour over the screen. We have switched it off and then on again, but still flashing 0.5m. Can you help?
First check and clean the transducer. Make sure it's level and clean of any dirt oil or fuel. You can do a hard or soft reset also but you'll lose all stored data and it will reset all of your settings. You can find out how to do a hard or soft reset on Lowrance hompage. www.lowrance.com I would get you the exact address but their web site is a little messed up this morning.
Jun 25, 2008 | Lowrance Iway 500c GPS Receiver
Lowrance LCX-25c GPS Receiver Logo
125 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
